Question about Maytag Dryers
Need new fin installed - Maytag Dryers
  • 1,531 Answers
You can replace the drum vains by lifting the lid to the dryer and then you can get to the screws to change the part out
Posted on Sep 08, 2010
One of my dryer fins fell off how to get it back on
Look inside the drum at the place where the fin was on the drum.
Do you see any screw holes now showing?
That will tell you that you need to take the machine all apart and re-fasten the fin on with some screws, unless the holes are stripped out in the fin itself, in which you will need to get a little bigger screws, or buy a new fin.
Oh yes, I have been using an epoxy cement in a tube that has 2 chambers, and this may help you.
I think it would work here, but will not be strong enough to glue the fin back on.
I sort of think it would stand the heat if you used it to help secure the screws into the fin.
Honestly, to me the new fin sounds " hard to get".
Be blessed.
Feb 03, 2013 | Maytag Neptune MDE5500AY Electric Dryer
My new ac does not have a place to plug in the freeze control.
It won't be obvious, you have to install as per instructions. If it's a round metal type, it goes way down in left lower corner. Feel for tube/return coils, at end of fins and clip it to them. If it came with a straight thin probe, reach up about 2"-3" above bottom of fins and gently push in and wiggle until it is inserted in between fins all the way until almost flush at wire end to hold it there.
Aug 27, 2011 | Dometic Rooftop RV Air Conditioner
We bought a new fin but can't get it back in the drum
Remove or pop the top. Once that is raised then you can install the fins easily.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 06, 2011 | Washing Machines
New rad installation
Baseboard such as Slant-fin is made with a bracket that will allow you to run a 3/4" dia copper pipe back over the top of the finned area as a return pipe giving you a supply and a return on the same side. Both the finned pipe and the housing can be cut to any length and come in a 3' section from the factory.
Jan 20, 2010 | Marley Electric Hydronic Baseboard Heater,...
I have an MDE7600AYW electric dryer and two of the three fins came loose inside the dryer and one of them is now lost. Who can I contact to purchase a new one with the installation screws???
The fins are called "Baffles" and you can find the parts at the link below:
http://www.partselect.com/PartDetail.aspx?Inventory=2035811&SourceCode=1
Jan 06, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Two of the three internal fins in the dryer came loose and detached from the inside of the dryer. Now the dryer is losing heat where the installation holes are located. Can I purchase new fins and install...
if you open the dryer by removing the top and front panel/door assy you can look at the bottom of the unit and find the old screws, buy the new fins, and re attach them if the holes in the dryer where the screws attach to the fins are too large for the screws use some washers
Jan 06, 2010 | Maytag Dryers
Power steering cooler
Doesn't sound like you had much of a cooler to begin with. You should have no problem deleting your cooler.
Mar 14, 2009 | 1992 Chevrolet K1500
A tumbler fin
This isn't much help, but those fins will break off. I have had them break off. I am ordering some new ones, called "baffles" and will be installing them. I hope I can the top open on the machine.
Jun 16, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
F50E New Power Supply Arcing
check the fins on both cells for even spacing on the fins. If the fins are bent a little, this will cause your arcing.
Pull both cells out and reinsert them one at a time. Keep the cell all the way to the front or all the way to the back so it makes contact with the power supply.
The cell that has bent fins will continue arcing. Good luck.
Nov 13, 2006 | Honeywell Enviracaire Elite F300E-1019 Air...
Dryers Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
