Question about Sony Audio Players & Recorders
Sony receiver STR-AV460 stuck in standby mode and don't have remote to change it. Not sure how in got switched to standby mode, but need to get it out of this mode.
  • 35 Answers
Try to unplug the AC cable from the wall for a while. However this may erase some recent programming, despite Sony AV receivers have memory enough to keep programs. Hope this may help.
Posted on Sep 08, 2010
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
How do i get my sony DA30ES am -fm reciever out of protector mode
Here is a guide for you: STR DA30ES Protect
let us know how , if you need further assistance.
Jun 09, 2012 | Sony STR-DA30ES Receiver
Trying to program dish network remote to sony str de 445 amp;
We would be happy to help with that. Here is a list of some of the codes that we have for Sony Amplifiers: 500, 645, 687, 639, 846, and 765.
Press and hold the AUX mode button until all mode buttons at the top of the remote come on, then release. Enter the number 2 then * then one of the codes for your Sony amplifier provided above.Press the pound (#) button, the mode light should flash three times. Check that the code works by trying severaldifferent functions on the remote to make sure it will properly operate your Sony amplifier.Keep in mind that some codes may not be compatible with your equipment. If thisis the case, please try the other codes listed for that device until you findone that is compatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
Aug 01, 2010 | Sony STR-DE445 Receiver
Can't change FM input mode! Stuck at analog...
Tuner is only analog. As for the Video 1 input you need to go into the menu and change it to the digital port you want to use (optical, coaxial or HDMI) you can set only one input to each digital input port.
Nov 30, 2009 | Sony STR-DE597 Receiver
Operating instructions for sony str-d565 receiver
this is a link just make sure to disable protected mode in internet explorer sometimes it has problems with links
http://www.docs.sony.com/release/STRD665.PDF
Feb 23, 2009 | Sony STR-D565 Receiver
Receiver stuck in protect mode
surely i can reset this myself without paying sony!
Feb 01, 2009 | Sony STR-DE545 Receiver
Sony receiver does not change components
Check to be sure that none of the buttons are stuck on. With the unit off, press each of the buttons. You should be able to feel the button engage. If they all feel like they are working, the internal switch itself may be shorted in the closed position.
Update this with what you find.
Dan
Aug 18, 2008 | Sony STR-DE197 Receiver
Receiver misinterpreting IR signals
There can be a few causes of this. Since it happens with a number of remotes, we can state that the problem is inside the receiver. In the front of the receiver (inside) you should see a small silver box. Inside that is the InfraRed receiver. This is a 3 pin device. Check to be sure that the pins have good solder joints. A bad joint can cause problems. Also, after the receiver comes what is called a digital switch. This is similar to a transistor except that it makes the transitions more steep, like a step rather than a ramp. If this part is bad you can get these results. The digital switch will be marked c124 (perhaps or somehting close).
Check these out and keep us posted.
Dan
Apr 09, 2008 | Sony STR-DA3ES Receiver
Stuck in HP 2CH
one of the transistors seem to have been installed in the wrong direction.if it is working it will blow off again As for the remote , it works via a separate circuit.
Feb 05, 2008 | Sony STR-DE597 Receiver
749 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
