Question about Emerson EWL2005 20 in. LCD Television
Red indicator lite only comes on for a second when on button is pushed.Tv will not power up . I replaced the two caps in power supply,but no change.Emerson model EWL20S5b. I need help checking power supply further.
  • 2 more comments
  • mcgiverlord Sep 08, 2010
    I don't know exactly where to ck voltages and how to check power transistor. Whould it help if I took a pic ? thanks Ron
    I'm a retired electrician with some electronics experience , but working without a schematic is difficult for me because I don't have labeled voltage check points. I will keep trying on my own because the tv is 5 yrs old and not worth putting a lot of money into. thanks Ron
  • mcgiverlord Sep 09, 2010
    Is there anywhere I can get a schematic? thanks Ron
  • mcgiverlord Sep 11, 2010
    I haven't had time to do any further trouble shooting yet, but the info you gave me sure helps. thanks
    President:
  • 1,961 Answers
That is not a DIY problem this problem requires a technical knowledge to fix it.It is more technical.I would suggest to bring your TV to a repair shop. thank you!
Posted on Sep 09, 2010
  • 1 more comment
  • Danilo Baraquiel
    Danilo Baraquiel Sep 09, 2010
    Ok sir, this is probably what you need... the schematic diagram of the power supply of Emerson EWL20S5b
  • Danilo Baraquiel
    If the diagram looks blurred to you, find a clear one on the link below. I might as well give all the diagrams that Emerson WWL20S5b have. From LCD, video, audio diagram, dis assembly instructions, replacement parts.. All you need to know about this LCD can be find in this service manual. If you have Adobe acrobat reader installed in your system you can view this because its pfd format. This is the link: http://www.scribd.com/doc/3744643/Emerso...
  • Danilo Baraquiel
    Sir, please give this answer a 4 thumbs up rating if this is the answer you need. Thanks for using Fixya.
  • Emerson Master
  • 5,138 Answers
Google to this Website and Type in your model number
Encompass Parts Distribution 1-800-638-3328
They should list Parts/Prices You might need to just replace the whole board.
  • ladywinn
    ladywinn Sep 11, 2010
    Partstore.com might have one or try HBP Electronics.online
  • Emerson Master
  • 11,800 Answers
Find the 115 volts line that goes to the high tension/flyback transformer then disconnect it - unsolder the safety strap or the first resistor. Without it the power source should start long enough to test the other voltages from the outputs. If none of the voltages is present then check the power transistor of the source and the rectifiers  - if they are ok then the transformer of the source is gone and must be replaced. If one of the voltages is lower or not at all then test all components that are poweredby it.
If all voltages are on then the high tension block is faulty - replace the power transistor. If the transistor is fried immediately then the flyback transformer is fried - replace it.
Posted on Sep 08, 2010
  • Azrael SRL Sep 08, 2010
    If you don't know where to check then how are you going to know what part is good or bad? How are you going to know how to test them ? If you touch by accident something that you shouldn't it can easily kill you  - it's 25,000 volts in there. And even if it doesn't kill you it will surely fry more parts making the repair even more complicated and expensive.
    Sorry, but i think it's time to call a pro, this is beyond your level of expertise.
  • Azrael SRL Sep 09, 2010
I have a Hisense LCD T.V. model H32V77C. Power indicator is red. When I push the power button, indicator turns blue, then blinks red 3 times and returns to blue, then shuts off.
hi sounds like there's no backlight voltage, check power supply board for any swollen caps, if ok, test the voltage on the white connector from the power board to the inverter board , with a meter should be 24v dc thanks
shaun
Mar 21, 2017 | Hisense Televison & Video
More detail --- Toshiba md20q42 tv/dvd combo not powering on, initially when it happened i Hit power button and lite came on and blinks for about 3 seconds then turns off--- now when i push power button...
Hi
It is probably a power supply problem associated with standby circuit. If this circuit is bad the set hardly comes on and fails. This is a task for a technician to trace the fault through the whole power supply.
Sully
Sep 22, 2013 | Toshiba MD20Q42 20" TV/DVD Combo
LG55LH40 LCD TV wont come on
The set will need to be properly diagnosed. It could be a defective main board or power supply.
Sep 01, 2012 | Televison & Video
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
Samsung model a3079dh hdtv 5 blinking lites when pushing power button
Remove the back and check for bulged electrolytic caps on the power supply, or replace power supplu. You can go to www.partstore, for anew supply.
Oct 16, 2010 | Panasonic TH-42PHD7UY 42 in. HDTV-Ready...
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
Emerson EWL2005 20 in. LCD Television Logo
167 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
