Question about Janome Memory Craft 9000 Computerized Sewing Machine
Bobbin keeps balling up. I have taken everything apart and cleaned it out. I have changed the bobbin and needle. What else can I do
    Problem Solver:
  • 5 Answers
I would suggest a new bobbin casing, yours maybe damaged. Also, you may want to check the tracking under the bobbin casing for any dust or lint. This will throw the bobbin off track.
Posted on Sep 16, 2010
Trouble shoot message. Thread is tangled. Needle is bent.
  1. Upper thread or lint is caught around the check spring.
  2. UNPLUG machine before you take off side cover!
If you don't know how to open side cover take it into your repair tech.
Jul 29, 2015 | Baby Lock Espire
I have a ce 4000 computer sewing machine. I cannot get it to work properly. The bottom thread keeps punching up. I have taken it apart & cleaned it,checked the bobbin, changed the needle,checked t
have only read that the bottom tension needs to benpulled tighter when threading by holding the bobbin and pull it tightly thru the needle hole in presser plate
Sep 25, 2014 | Brother CE4000 Computerized Sewing Machine
The bobbin thread keeps balling up when trying to use my 730 on quilt motion system
try changing the needle
try turning the bobbin the opposite direction in the case
make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
if these suggestion don't help then the machine needs to be checked
Mar 06, 2013 | Bernina Sewing Machines
My brother 770 keeps saying safety device has been activated, I have taken the bobbin case and everything off and cleaned it, have also changed the needles, etc. it will sew for a few minutes then messes...
check to see if the top thread has come off the thread take up lever
trying turning the bobbin over the opposite direction
also possible that there is a timing problem with the machine and
it needs to be checked by a repair technican
Dec 03, 2012 | Sewing Machines
Sewing fine, then heard a couple clunks. Machine stopped picking up the bobbin thread. I have taken it apart cleaned, oiled, new needle.
check to make sure the needle is inserted correctly
turn the bobbin opposite of what it is now
rethread the machine top & bobbin
if none of these suggestions help then the machine needs to be serviced
May 28, 2012 | Brother Sewing Machines
My bobbin thread keeps getting tangled and breaking everytime I try and sew....I have tried rethreading the bobbin, taking everything apart and cleaning out the dust and debris, I have adjusted the thread...
there is a screw on the side of the bobbin case, which needs to be turned to the left or counter clockwise to loosen the tension and also change the needle because a burr on the end will cause problems with bobbin thread
Dec 13, 2009 | Brother LS-2125 Mechanical Sewing Machine
On a babylock elegante the bobbin thread shows,
Have you reset the tensions for this machine, look in your manual and follow directions. If this is an Elegante there is also a set of instructions on the machine. On the LCD screen there is a picture of a sewing machine with a question mark, touch it, find Troubleshooting and touch that then find the problem you are having and read. If this does not help take it to a Brother dealer and have it reset so as to keep you machine in good running order.
Jul 05, 2009 | Baby Lock Ellure
Needle won't pick up bobbin thread
Is it possible the bobbin is in backwards? I have also found mine to be fussy with cheap bobbins.
Jan 20, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Bobbin
Hi Sally,
Don't forget to change your needle too. It may not look bent, but it probably is.
Nov 06, 2006 | Rex RX-1804
Janome Memory Craft 9000 Computerized Sewing Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
