Question about Oreck XL Ultra Bagged Upright Vacuum
Trips circuit breaker will not come on - Oreck XL Ultra Bagged Upright Vacuum
  • Oreck Master
  • 17,129 Answers
Remove from the plug and then push to reset.If the breaker trips off again the fault can be due to high current factor in the motor.
Release motor circuit to test.
Posted on Sep 08, 2010
Rainbow pn-2e circuit breaker
The circuit breaker could be defective.
Aug 19, 2016 | Rainbow E series Canister Wet/Dry Vacuum
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
Circuit breaker trips with shark steam mop
figure out how many amps your circuit breaker is
then figure out what appliances are running from that circuit
if you are under...then your mop is faulty
May 25, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My series 90L suddenly stopped and would not restart. A check of the circuit breaker found it tripped. The vac would not turn on when the circuit breaker reset. Using an AC voltage sensor indicated power...
From the description it sounds as if there had to be a short in the unit somewhere. This is what would have tripped the breaker. the fact that it is not tripping could mean that there is a fusible link or that the wires or whatever have burned back from the short, and are no longer shorting out.
Jul 04, 2011 | Vacuums
My e wave microwave appears to be in fine working order until the door is opened. It then trips the breaker and ceases working. Ater the house breaker is reset, the power is restored to the microwave...
You may have a short circuit on the INTERIOR LIGHT BULB circuit in your microwave.
This might explain why the breaker trips every time you open the door.
If so, you would have to unplug and disassemble the unit in order to access the wires and light bulb socket inside the case in order to troubleshoot and repair the problem.
If you are unfamiliar with safe electrical troubleshooting and repair procedures, please be extremely careful or consider hiring an electrician to do the work. There are some hazardous components inside which remain dangerous even after the unit is unplugged.
Good luck.
Apr 19, 2011 | Vacuums
My vacuum worked just fine... i went in another room to use it and now it won't turn on no matter what outlet i use!
If it works in the other room's outlets, I would think that it might be tripping the circuit breaker for the room it isn't working in. Check your circuit breakers.
Dec 07, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
Circuit breakers frequently trips
Is the breaker that trips inside the Dyson, or for the wall power plug?
Dec 17, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Hoover Windtunnel blew the circuit breaker today, and did so again after I reset the breaker and turned off the only other appliance on that circuit. Any advice? Thanks from GrGrandma in Fremont
There could be a problem with the vac, the only way to know is to use an ammeter and test the current draw of the unit. If the vac is ok, the breaker could be failing. Plug the vac into another receptacle on a different breaker and see if it still trips the breaker; if it does, then have the vac checked out
Aug 18, 2009 | Vacuums
Eureka Vaccum Tripping Breaker While in Use
ur overloading the circuit in the house try turning off everything that is on that surcuit i mean everything then see if the vac works
Apr 04, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
138 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Randy Schumann
Randy Schumann
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
