Question about Comstock-Castle 2F330-3RB Gas Range
We have a C330 Comstock Castle, and want to know what kind of manafold pressure it needs, and what kind of control is recommended. We are converting it from LP to Natural gas. Thanks!
  • 6 Answers
The design pressure for Castle ranges on Natural gas is 4" W.C. (water column) Make sure you change or convert the pressure regulator in the rear and change the orifice tips on all gas valves
Posted on Sep 08, 2010
After getting a new catalytic converter with manafold I also replaced the fuel cap and got the code PO449 what else could I do without spending lots of money to get car smogged?
What make,model and year of car? Why did you replace the Manifold and catalytic converter? Did you run a exhaust back pressure test before replacing the converter? Did you clear the codes after all repairs,then run the vehicle on a road test and the code came back?
May 11, 2015 | Cars & Trucks
Ssssssss
What's your problem? Susan Restaurant Equipment Outlet 888-542-5959
Aug 27, 2011 | Comstock-Castle 2941SF Deep Fryer
Pressure builds to 150 psi but the regulator will not increase above 60 or so psi. this is causing the nail guns to not shoot correctly.
When the regulator fails, usually air will leak from under pressure knob, however in your case the nut must be stripped of its thread. May need to replace the manafold for fix(most regulators are built into manafold). To allow you to continue using the compressor, add another quickconnect at pressure release port. Let all air out of the tank. Remove pressure safety release, and install tee fitting. Re-install pressure safety on one of the ports of the tee fitting and a quickconnect at the second port. You will have tank pressure available while you order the manafold. Or just add a generic regulator before the quickconnect and forget about replacing manafold. Good luck.
Aug 20, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Half way through heating pilot goes out
Sounds like your thermostat is bad, and/or high limit switch too. Check the thermostat first, and if you replace that, and it still does not work right, then the high limit next... Feel free to call Comstock Castle and ask for help directly through their parts/warranty dept. They should be happy to help you troubleshoot the problem.... Susan Restaurant Equipment Outlet, Cinc, OH
888-542-5959 www.restaurantequipmentinc.com
Aug 14, 2011 | Comstock-Castle 2941SF Deep Fryer
I own a Comstock-Castle Range model C330-11.It has been converted to use propane. It has 4 burners @ 13,000 BTU ea and a griddle @ 20,000 BTU on the stove top. It has a single oven with no broiler @ 25,000...
Castle ranges don't require a electrical plug. If converted to LP/propane make sure the water column (WC) is set to 10 inches. If it is less you will have pilot light problems even if the thermocouple is strong. If set at 10 inches, most likely problem is the thermocouple. Correct replacement at Castle is approx. $25. The manual for current ranges should cover most issues but the Castle stopped making the C series ranges in the 80s. All controls and most parts are still available.
Jan 19, 2011 | Comstock-Castle 2F330-36 Kitchen Range
What do I need to do to switch over from natural to LP gas?
You will need the following Castle part #s
17003A- Pilot head assy LP gas @ $49.
17006L-Convertible Press Regulator LP gas @$29.
Give Castle Stove a call @ 800-637-9188 to make sure that is all that you will need. They were the only two parts I found on there website (www.castlestove.con) under your model # for LP gas conversion. There might be a need for a conversion kit for the gas valve.
captrick
Jul 20, 2009 | Comstock-Castle 2616HG Deep Fryer
Shallow fryer pilot light goes out
Call fafctory service dept 800-637-9188 ext 22
May 27, 2009 | Comstock-Castle 14HF Deep Fryer
Dewalt D55155 air compressor regulator installation
The d55155 unit suffers from regulator problems due to weakness in the design of the manifold. The manifold parts are very light duty metal and will break during installation if not carefull. If you can return the parts to dewalt it may be more efficient to to use a generic pressure regulator from www.grainger.com for about 20 bucks and mount using a couple of 1/4" tees directly off the pressure switch. Remove the hose from the pressure switch that feeds air to the manafold . Install parts so that the quick disconnects, guages and new regulator are accessable from the side. It will not be pretty but problem will be solved for long term. We repair other brands that come with control panels using the same method. Pressure regulators built into a manafold will fail. For demanding customers we have recreated the manafold using 1/4 pipe fittings and refit the gauges and grainger regulator into panel.(lots of work) But leave the safety unloader at the pressure switch. If all you need is a good functioning compressor same time and money and mount to side. Good Luck and email if you have questions or other issues with your dewalt.
Feb 19, 2009 | Black & Decker Dewalt #D55155 2HP 4GAL...
Comstock f3226-24 for Residential Use
yes but you might have to upgrade your electrical plug in some of them use more amperage than a home is set up for at the circuit breaker. please check into that before you make the change
Dec 07, 2007 | Comstock-Castle F3226-24 Gas Kitchen Range
Garmin C330 partially dead
It does sound like you might have a problem with a loose or broken connection. Since these units are not designed to be serviced by the user, and you risk further damage attempting to open the unit, I would recommend it be sent to Garmin for service.
Sep 05, 2007 | Garmin StreetPilot C330 GPS Receiver
Comstock-Castle 2F330-3RB Gas Range Logo
255 people viewed this question
Top Comstock-Castle Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Comstock-Castle Kitchen Range Expert? Answer questions, earn points and help others
