Question about Lexmark X2600 InkJet Printer
Printer is making clicking sound after dropped to the floor
  • Lexmark Master
  • 17,130 Answers
Possible that you would have damaged the printer harware inthe fall. So in the first place remove the power supply and check for crack inthe board. If the power output is showing the required DC, the checck the main mother board for cracks, checck using magnifier and resolder suspected joints.
Posted on Sep 08, 2010
Accidentally dropped it on the floor and now it starts but wont open
That clicking sound is called "the click of death" so the last part of your question is correct, it's broken; replacement is the only cure.
I don't know if you have access to a clean room, but that would be the only place you can open it without contaminating the drive.
Jan 25, 2015 | Computers & Internet
Has clicking sound and it is not detected by my laptop. I need the data inside. Help !!
I fear that your hard disk (usb 2.0 or 3.0 ? your title indicates both) is dead. Dropping disks onto the floor is not good for them. Always keep back-ups of your data, and make them regularly.
I suggest you contact Seagate. They may replace the disk if it is within warranty. They also offer a data recovery service if your data is important (you will have to pay for this).
Read this article about dead hard disks:
http://www.hardwaresecrets.com/printpage/245
25.April.2014
Mar 03, 2014 | Seagate 1.5 TB USB 3.0 FreeAgent GoFlex...
Its identifying my printer as being offline, how do I correct it
Click on startà control panelàprinter and faxes.
Click on top left Add a printer option. This launches the Add Printer Wizard. Click next.
Select Local printer attached to this computer and uncheck automatic detect and install my plug an play printer option then click Next.
Now, Use the drop down arrow to select USB001 then click next.
Select the Manufacturer as HP from drop down list and select DeskJet 990c from printer drop down list. Click Next.
Verify the printer name and set the printer as default then click next.
Do not select print a test page option.
Click on Finish
Click on start then run type notepad.
Write any stuff and then try to print.
ADD A PRINTER IN VISTA
Click Start and click Control Panel.
Click Hardware and Sound then Printers.
Click Add a printer. This launches the Add Printer Wizard.
Click Add a local printer.
Now, Use the drop down arrow to select USB port 001 then click on Next.
Select replace current drivers
Click on Finish.
Click on start then search type notepad.
Jul 10, 2010 | HP Officejet 4315v All-In-One InkJet...
My hard drive dropped on the floor and now it is making a click, click, click sound
its dislodged the read write heads and lost the FAT (file allocation table) so its probably now a paperweight
Jul 12, 2008 | Computers & Internet
Problem printing
1) Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 29, 2007 | Epson STYLUS CX3900 All-In-One InkJet...
Color printing problem for Epson CX4200
try this :
Please confirm that the head cleanings were done using the most effective method listed below.
3) Click on START.
Dec 29, 2007 | Epson Stylus CX4200 All-In-One InkJet...
Dark red prints with lines throught the picture
1. Make sure the printer is turned on but not printing.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 23, 2007 | Epson Stylus Photo R320 InkJet Printer
Printer doesn´t print using the mangenta ink cartridge
try this :
3. Click on START.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
Dec 20, 2007 | Epson Stylus C63 InkJet Printer
Printing in blue only
try this:
1) Make sure the printer is turned on but not printing. Ensure there are no error lights or messages appearing in the LCD.
3) Click on START.
Dec 12, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Color of prints very faint
It is unfortunate that you are having this difficulty with your printer.
To help preserve the life of the ink cartridges we suggest that you turn the printer off when it is not in use.
1. Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
3. Click on START.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s), your printer will require service.
Nov 19, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Lexmark X2600 InkJet Printer Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
