Question about KitchenAid Refrigerators
Doesnt make ice - KitchenAid Refrigerators
  • 1,531 Answers
Check the fill tube for the water to the ice maker and make sure it is not blocked with frozen water. if the tube is clear you may need to change either the ice maker or the water valve.
Posted on Sep 08, 2010
Ice doesnt come out of ice maker , seems to get stuck. Have to stir ice around
Hello Phyllis Hopkins, thank you for your inquiry!
It sounds like you could have a possible issue within the dispenser, auger, or auger motor of your Frigidaire refrigerator. Since it could be any one of these underlying issues I would recommend having a technician come out to properly diagnose and repair your appliance to avoid any unnecessary part purchases. -Matt
Sep 08, 2014 | Frigidaire Refrigerators
Kitchenaid icemaker
Hi, you need to provide more details. Does the icemaker power on when its put on and doesnt make ice or it doesnt power on at all? More info is needed pls
May 05, 2013 | Kitchen Appliances - Others
I'm having problem with my icematic 132M . I freezes the cubes allright , but the cubes doesnt fall out before the harvest stops, so the cubes is still hanging on in the machine which causes the m
First i would clean the machine per manufacturers instructions with nickel safe cleaner and sanitizer. When the plates get dirty it will cause ice to hang on to plate. Also check the thickness of ice if to thick it will not come off plate.
Oct 08, 2012 | Ice-O-Matic ICEU220HA Undercounter Ice...
How do I fix the max harvest time shutdown
The ice sensors are not sensing the ice fall.Wave your hand in front of them the bin full light should blink.If it doesnt clean eyes and conectors.If it still doesnt blink change them they are bad.
May 21, 2011 | Scotsman Ice Maker 600LB CM3 30inW...
Ice auger not working
normally someone has removed the bin to empty the ice or it was pulled out a little by accident. Try removing the bin and make sure that no ice is jaming the auger motor try turning the auger by hand. Hold down on the door switch and have someone push the demand buttom for ice and see if the motor turns. If it does reinstall bin. If it doesnt make sure ice has not blocked it. reinstall bin and try the ice button. hope this helps if this doesnt fix it the drive motor has went out.
Aug 11, 2010 | Kenmore 50532 / 50534 Side by Side...
LG LSC27931st.ice dispenser flap doesnt close after ice drops
Not that this is much help, but I have the same problem with the same model.
Dec 02, 2009 | LG LSC27931S Side by Side Refrigerator
My icemaker doesnt make ice even after i replaced the filter and pushed the accelerator ice. Water does come out just not making ice.
Check the ice maker water fill tube. It is probably frozen inside. Remove it. Thaw it. Dry it and re-insert it.
Jul 07, 2009 | Kenmore Refrigerators
The ice maker doesnt work, and in the day several times appears water in the floor, in the side of the door of the ice maker
Uplug refrigerator and remove the ice maker so we can look at the tube that comes into the back of the ice maker. It maybe the ice maker is calling for water but ice or a crack in the tube that delivers the water is being deverted to inside the freezer area. Also look behind the fresh food compartment door and see if you can send me the model number so I will be able to go over the correct model. Let me know, Thanks, Sea Breeze
May 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker doesnt stop making ice
Check with an identical unit to see how that one moves. Yours may be dislocated. The lever arm probably contacts small plastic parts in the timer that could be out of place. Ice makers aren't too tough to take out and check out in a more comfortable work location. Just put a towel to catch screws.
Apr 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker
remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Sep 10, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
