Question about Whirlpool GHW9100L Front Load Washer
GHW9100LW2 Whirlpool front load washer does not drain or spin
  • 1,531 Answers
Use a wet dry shop vac and remove all the water from the unit then check or remove all the hoses from the drain pump and loock for any obstructions in the pump or hoses.
Posted on Sep 08, 2010
Ghw9100lw2 Duet washer will not drain or spin. was flashing a "F" on the display...
remove the lower panel on the machine and you will see the water pump and right next to the pump you will see a drain plug --- turn the plug counter-clockwise and unscrew it. let it drain,, and clean out any blockage that may be in there. after it is clean,, re-install the plug and start the wash cycle,, this should solve your problem.
if you are still having troubles - please feel free to write me back here,, Ii will do my best to walk you through any steps needed.
c...
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Vibrating Whirlpool ghw9100lw2
At Lowes you can purchase foam rubber pads 4"X5" pack of two for $3.50. If walking forward and after cecking level and washer pads are tight, place half of one pad under each of the two front feet. Place the sticky side against washer feet. Solved my problem.
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Squeeking noise on whirlpool washer duet ghw9100lw2
replace your belt in back easy.every year if still has smell buy warranty your rear bearing is going bad."less soap plz"
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer model number GHW9100LW2,SER# CSR2021497
Central Control Board part 8182221. You can go online repairclinic.com to order parts.
Good luck
Jun 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9100lw2 front load washer doesn't use both hot and cold
first make sure the hoses aren't reversed hot on cold or cold on hot next turn off cold water remove the hose from the washer and check to see if the screen on the washer is clogged if not get a bucket turn on cold water and see how strong the water is then let me know what you find dont rate me till we are done
Jan 10, 2008 | Whirlpool GHW9100L Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
125 people viewed this question
Dan Webster
Dan Webster
Sal De
