Question about NEC Electra Elite DTU 16D-2 Corded Phone
My line 2 light is stuck on as if it is busy and It IS NOT in use. I have checked all the phones to see if a button is stuck on any but there isnt.
Every extention on the console is showing with the red led light, as if the lines are busy. Therefore I cannot transfer calls, when in actual fact, the lines are not busy
ouch, sounds bad...
possibilities~
1) everyone has DND turned on if so have them disable their call forwarding entirely (intercom*7100)
2) your buttons are all suddenly programmed wrong, reprogram them to the correct extensions
(press "PROG" then the button you want to program, press " 1 " then the extension number, then enter)
3) major error with the system, have a serviceman come out and take a look
Jan 04, 2011 | Panasonic KX-T7630 Corded Phone
CO button light was stuck so to clear it i pressed Prog, then CO button, then 2 (clear) and then enter. Doing this cleared the light but it also cleared the extension associated with it. I have re-added...
What was 2? Extensions are put in with a 1. The 2 is used for internal or speed dial calls (as in 29 plus a number gets you speed dial).
If you assign a digital station that is not in service to a button, you will get a busy light.
Carl
Nov 23, 2010 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7730- assigning speed dialing/one touch. I tried to press prog button and the one touch button..but it gives me an error message "not stored". How to solve this? I have 12 buttons to assign...
It says "Not Stored" because you haven't stored anything in it. There are 12 buttons on the left side with lights and 12 buttons for feature dialing on the right. If you want to monitor extensions, the buttons on the left are the ones to use. If you want to store speed dial numbers and feature codes use the ones on the right.
Left button programming. Press PROGRAM and the button. For extensions, dial 1+ext and STORE. For CO's, press 0+line number, for inside codes press 2+code, for outside number press 2+9+number, all followed by STORE.
Right button programming. For inside codes dial the code, for outside number press 9+number followed by STORE.
Note that you could also dial "8x" or "80x" in place of "9" for specific line access. Also, you can store extension speed dial numbers on the right, you just won't get a light indication when they're busy.
Carl
Jun 04, 2009 | Panasonic KX-T7730 Corded Phone
My vetech cordless phone is not working
DO you have a 2 line model? If so check and make sure the conf (conference) button is not pushed as it will keep the line off-hook forever. Hope this helps!
Mar 28, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
MY PHONE SAYS "MAKE BUSY" ON MY LINE. IT WILL NOT FWD TO VM/ ONLY BUSY!!
I was given a set of codes to use to reset the "make busy" sign, which was **1, not sure if these codes pertain to all phones, and to turn off "head set" i was told to use **3. I was then able to see the date and time again!! I also was able to pick up my phone when it rings instead of having to press a certain ext to answer from.
Nov 03, 2008 | Mitel Superset 4025 Corded Phone...
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
RCA Phone model 252025 - displays Answer... on line 1
The Thomson folks said to reset the phone. Here's how: unplug power, then the phone line, then remove the batteries. Wait 10-15 minutes. Replace the batteries, then the phone line and finally, the power.
Note: We have 2 phones with these two lines and had to reset both of them to clear the "busy" on Line 1.
Sep 05, 2008 | RCA 25205RE1 Phone
RCA ViSYS 2 line business speakerphone
well 2 things, do you have voice mail and is it on the lines the phone is connected to??
Nov 19, 2007 | RCA 25202RE3 Corded Phone
Message Indictator
hi its hard to understand... the phone is connected to line 4 or not? if so and line 4 is dedicated to fax line then the fax tone is the cause of your confusion fax tone is different from a regular tone phone if the phone isnt connected to line 4 and only to all 3 ordinary lines - then the phone is getting a over volage from them and activates the light & messege alert my advice let it be you will start playing with it something else will go worng... good day
Feb 19, 2006 | RCA 25414RE3 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
137 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
