Question about Samsung CLX-2160N All-In-One Printer
Samsung clx-3160fn printer Jams near constantly - error "0" meaning the first set of rollers. When I remove the paper tray, there is a sheet of paper laying underneath, with a little bit of the very top of the sheet in the printer - I pull it out easily. Also have to open and close that back door, but there is no paper there/no jam there. Samsung tech told me to clean the rollers visible from the back door, but that did not solve problem. I am using the correct paper, not fuzzy bond or anything like that. Are there other rollers to clean? The paper tray appears undamaged, and sometimes it will print 10 or fifteen papges before it jams. Wondering if overheating.
  • dmm_buffalo Sep 08, 2010
    Yes I suspect there are dirty rollers, or maybe worn rollers (although i haven't given it frequest use), where the paper is jamming. So, how do i get underneath? (these are not the rollers which are visible when you open the rear door) Do I take out the toner and turn it on its side? Are there other pieces i should remove before tilting the printer, like the waste reservior? Are the rollers visible once i turn it over? what should i use to clean them - just water? should they be removed or just cleaned in place? I will also try pushing a sheet of smooth cardboard into the underside rollers, just in case. If that doesn't work, where do I get replacement parts - only samsung?
  • 526 Answers
If its not grabbing the paper at the front, most likely the rollers are worn out. Washing them can help, but replacement is optimum. Also you make want to take light card board (for example, envelope used for priority mailing) rip it in half and use only 1 side, and manually force it up the area where the paper stops, they maybe a small piece of jammed paper in there
Posted on Sep 08, 2010
  • adi Sep 08, 2010
    I dont know how good you are with taking things apart, so I would suggest first
    taking the paper tray out as well as the cartridges. turn unit around so you are facing the back and if possible have the printer stick out over a table just enough so that you have access to the rollers and try to clean them, if still does not help, put unit on side, carefully.
    there is access to the rollers if certain parts are taken out, but but requires some work
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
Paper keeps jamming on Samsung CLX-3160 FN. How do I prevent this from happening?
Paper jams are typically caused by the rubber rollers inability to put paper through the machine. Try cleaning the roller with damp rag to see if that improves performance. If the roller is badly worn, it will need to be replaced.
Oct 04, 2010 | Samsung CLX 3160fn All-In-One Printer
Constant paper jam
This is usually caused by a worn or dirty feed roller. You can try to clean it with a damp cloth or brush, otherwise you will need to have it replaced.
Jun 22, 2010 | Samsung CLX 3160fn All-In-One Printer
How do I replace the tray 1 pick roller for my samsung CLX 3160FN printer?
Take out the tray, and you will find a pick rubber roller at the base.
Even you may clean and use it.
Jan 07, 2010 | Samsung CLX 3160fn All-In-One Printer
Constant Paper jams on CLX-3175FN
The fact that there appears to be no actual jam tells me that it is not picking up paper out of the tray. Try some alcohol on the pickup rollers, rubbing well. If that helps, replace these rollers.
Aug 12, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Paper jam
It jams due to the rollers. Please change the rollers and it should be good. also pay attention to the way the paper is being seated in the drawer.
Jun 29, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung 6210 paper jam
open access(load area) check feed roller take a q tip and use rubbing alcohol and clean photo eye that detects paper be sure all jammed paper is removed
most jams are at the exit and there may be some paper obstructing that area
insert card stock through the paper path
insert ine
Dec 30, 2008 | Nikon COOLPRINT Thermal Printer
Keeps jamming
check your toner cartridge and also u need to service the printer fuser aseembly.also change roller.or taplon tape.
thats all
also see there is not any paper jam in parts.
Oct 09, 2008 | Samsung CLX 3160fn All-In-One Printer
Printer fails to pickup paper out of paper tray
Use a soapy product suck as fantastic and clean the rubber rollers thoroughly.
They may be getting slick and in need of replacement also
Dec 07, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-2160N All-In-One Printer Logo
165 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
