Question about Dishwashers
I have an older bosche dishwasher and the I know the water is flowing into the unit and collecting at the bottom of the drain but it is not getting into the spray arms in the middle and top to work at all. Any help would be appreciated.. Thanks
  • 1,531 Answers
There is a chacne that the main wash motor is not drawing enough water into the pump to spray through the arms.you can try and add some more water to the dishwasher and see if there is any change.
if there is no change then you migh need to replace either the contol board or the main wash motor
Posted on Sep 08, 2010
Water is not flowing into the dishwasher. Initial problem was that it was not draining. It now drains but now it will not pump any water into the dish washer.
I have this same problem! Just started happening. My Bosch drains fine but only a very little water is entering the unit and it seems to be coming thru the arms on the bottom not the top. Help! I checked the arms and they are clear, drain is clean.
Apr 16, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
There are two hoses coming from my Bosch SHE45M06UC dishwasher. One is obviously the drain coming from the back of the unit, and the other is attached to the side looped and not connected to anything. I...
Many people realize the dishwasher connects to a little hose on the sink, it is called an air gap. However, many people wonder " The air gap is there to prevent the water from being siphoned out of the dishwasher. When water flows through the drain hose, it creates a suction on the water still in the dishwasher. The air gap, makes a hole for air to get in. That way, the water only leaves the dishwasher when it supposed to, when it is pumped out. Another benefit of an air gap is that if the drain hose becomes clogged, the dishwasher can still pump out the water. Instead of flowing through the hose, as it should, it can flow out the air gap and into the sink.
The dishwasher's drain line usually connects to an air gap mounted at the countertop level on the sink. The drain line continues from the air gap to either the garbage disposer or directly to the sink drain. If the drainage hose between the air gap and the drain is partially or completely blocked, wat
Aug 28, 2008 | Bosch Dishwashers
Bosch lifestyle dishwasher not filling with water. I undid the bottom and it blew out an air block and started. When reconnected again it is doing the same thing
hey can any1 help me I have a bosch automatic, when I turn the unit on the little fan in the bottom keeps spinning and no water enters the unit, iv drained all the water out of the unit cleaned the drain checked to make sure water is getting to the unit then I pulled the panel off the side and held down this red piece like a float valve down and it then fills with water, but its not completing a cycle, any advice what could be wrong?
Apr 09, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
The dishwasher fills with water when it it off.
The problem is the water inlet valve has failed. This is inexpensive and easy to replace. Here is a video that will walk you thru replacing this.
http://appliancehelponline.com/dishfloatwaterinletvideo.html
Jun 03, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Bosch logixx dishwasher draining constantly even with door open
there is a leak . when the unit stays in drain mode that means there is water at the bottom of the base. The float switch stays in drain mode untill the water is removed. you must take off the side panel to remove the water,let me know what happens.:)
Nov 08, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch Dishwasher SHU3032 - pump will not shut off.
Kill power to the unit. Access bottom of unit removing the kick plate. Hard to see under the machine but you will find that water is collecting in the white plastic pan under the unit. Stick a corner of towel in where you see water to soak up the water. When all the water is out, turn the water pressure down on your supply line to almost nothing. Adjust this pressure by turning the hot water on at your sink and adjusting it down by half. This will allow you to use your machine until you can replace your water valve on the dishwasher. The valve is allowing too much water to come into the machine and over flowing at one of the inlet components.
Apr 10, 2009 | Bosch 24 in. SHU30 Built-in Dishwasher
Bosch Dishwasher pump keeps emptying
Disconnect the power to the unit. Remove the lower access panels and check the tray under the dishwasher. You will probably find it is full of water. Use a towel or a sponge to remove the water. There is a float that will stop the operation of the unit and run the pump if water is in this tray. Test the unit. If there are no leaks, check the drain hose under the sink. THE DRAIN HOSE MUST RUN UP TO ABOVE THE TOP OF THE MACHINE THEN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overflow into the tray under it.
If there is no water in the pan under the dishwasher there may be a problem with the pressure switch at the side of the pump housing but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Bosch Dishwasher Parts: http://www.repairclinic.com/Bosch-Dishwasher-Parts
www.RepairClinic.com
Feb 11, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
Owen Barnes
