Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Circuit diagram for mechanical controlled microwave ovens:
  • KitchenAid Master
  • 9,098 Answers
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Circuit diagram for mechanical controlled - mini_manual_behind_grille_small.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your model number).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Sep 08, 2010
Microwave error code se
That would be a shorting membrane keypad.
On most of these, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It's actually a pretty easy do it yourself job.
A video is available here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
Apr 22, 2013 | Amana AMC5101AAS Stainless Steel 1000...
I have a panasonic microwave with convection oven, grill and steamer. When I switch on the microwave, the house fuse (16 amp) cuts out. With the other functions of the oven, it works fine. Do I need a new...
you have a short circuit.
test the a) HV rectifier b) Capacitor HV c) HV transformer d) Magnetron e) test the swich for door for short.f) circuit board main is short.
see the diagrams and proceed.
10_2_2012_12_41_44_pm.jpg10_2_2012_12_42_15_pm.gif10_2_2012_12_42_35_pm.gif10_2_2012_12_43_09_pm.jpg
Oct 01, 2012 | Panasonic NN-C994S Convection/Microwave...
After a short power outage, I have clock issues.
this a problem with the clock , but the microcontroller can be defective by the power outage, see the diagram . how the microncontroller has the control for any equipment.
IN SHTE M.CONTROL BOARD CAN BE DEFECTIVE. go to the repair shop Tv FOR FIX IT. God bless you
Jul 19, 2012 | Microwave Ovens
Microwave starts but doesn't give heat
you have the following problems:
1) internal switch 2) high circuit problem 3) control board , i recomend you call to some service tech. see the diagram attached.
God bless you
Jul 14, 2012 | Emerson MW8168B Microwave Oven
Hi ..Our Microwave stopped working. It is a GE Microwave- Convection Oven in wall combo with control panels for both ovens shared. Convection oven works fine. Microwave has no power...it is dead. ...
There is often a fuse and a magnetron thermal fuse or thermostat.
You can find links to helpful exploded view diagrams and order parts here.
Dec 02, 2010 | GE JE1460 Microwave Oven
The microwave won't stop beeping
Your membrane keypad has failed. I'm guessing it's giving an error code of F2 also?
On the KHMS155LSS# models, the membrane keypad is available as part of the control panel frame assembly which comes with a new keypad.
Replacing this is actually a pretty easy do it yourself job.
You can get the control panel assembly here.
You can also find helpful exploded view diagrams at that link.
Just enter your model number (as KHMS155LSS# for example where # is the last digit) without the dash.
Jul 06, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Sylvania type sm81001
Have you ever replaced the fuse with Higher Amps fuse. There is a circuit diagram inside the cover please refer to that and ensure that the rating is same.
Jan 04, 2008 | Sharp R-1480 Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
130 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
