Question about Kenmore Sewing Machines
What year was Sears Kenmore Sewing Machine model 158.18023 manufactured?
We bought ours new in 1967. I still have it and it looks like new. I have all the attachments and cams
Posted on Jan 09, 2014
SOURCE: thread a kenmore 158 13410????
Not sure if I am too late, but it's pretty basic. I have the same machine...
You have the thread on the spool with the thread on the left side (unrolling off the spool counterclockwise) and put it around the round thing on the front middle (looks like a snap sort of) and through the eye almost right in front of it (the loop) and hold the thread lightly then wrap the thread around the tensioner (the thing with the dial) to the left (counterclockwise) until the springs "pops" it into place. Then run the thread through the little hook thing (by entering from the left) then up to the eye (hole) that is in the little arms that raises and lowers (you might need to spin the wheel to get the arm in the right position) then you run the thread back through the hook thing (entering from the left) around the little half circle thing (by entering from the left) and finally in the hole in the needle...
hope it made sense, I tried to use laymen terms...
good luck!
Posted on Jul 09, 2008
  • 255 Answers
SOURCE: how to "tune-up" mechanical Kenmore sewing machine
Sure! Jenny at http://blog.sew-classic.com/categories/Sewing%20Machine%20Repair.aspx has several very good, in-depth articles about servicing your own machine, but here are the basic steps:
1. Take out the bobbin case and bobbin holder.
2. Take the needle plate off.
3. Brush out all the old lint in the bobbin area and under the needle plate. Remove any loose bit of thread.
4. Open the head of the machine (should swing open). Clean any lint or thread that's caught in there.
5. Locate your machine's oil ports and put one drop of sewing machine oil (only use sewing machine oil) in each of them. One drop is sufficient. General rule of thumb: Put one drop of oil wherever metal moves against metal.
6. Using unwaxed dental floss, floss the tension disks.
7. Put everything back together.
If you need a manual, I found one at http://pages.sewing-machine-manuals.com/173/InventoryPage/1834489/1.html.
Hope this is useful!
Robbie
Posted on Jul 30, 2010
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore 10 Sewing Machine
kenmore sewing machines relics
Posted on Jul 13, 2008
  • 69 Answers
SOURCE: Kenmore Sewing maching 158 15510: sewing mechanism
You put the hook (the half moon thing with a sharp point on it) in the machine by placing it opposite the little curved bar. Make sure it is seated properly on the ridge. The you take the race, the circular part with a small plate on the top and place that over the hook(the plate side will be facing up). It will only fit a certain way, it could have a slot that a notch fits into (that is usually how it goes). Then slide the arms over it and they will snap into place. Once done, turn the handwheel and make sure everything moves smoothly. If not, you'll need to start over as something isn't seated correctly. Then you can install the bobbin case as usual.
Posted on Mar 01, 2009
Manual for kenmore 38516221301 sewing machine
Sears carries manuals for most of their machines.
Jun 22, 2017 | Kenmore Sewing Machines
What bobbins to order? I need more!
Shop for sewing machine bobbins... on Google
Plastic Bobbins for Kenmore S...
$3.99
Sears Singer Transparent P...
$8.99
Google Trusted StoreOverstock.... Brother SA156 Top Load Bob...
$5.10
Walmart Sewing Machine Bobb...
$3.89
Sears Parts D... Janome Style J Plastic Bobbin...
$6.00
Sew Vac Direct Search Results
    Bobbin Style Information for Sewing Machines - The Thread ...
    www.thethreadexchange.com/.../merchant.mvc?...sewing-machine-bobbi...
    We have bobbin style information for over 1600 sewing machine makes and models. Please start by selecting a sewing machine make from this list.
    Sewing Bobbins : SewingMachinesPlus.com
Dec 08, 2015 | Sewing Machines
Looking for a manual for sears kenmore portable sewing machine model 158.13200
Search the internet for:
Manufacturer + Model + the word "Manual"
Nov 22, 2015 | Kenmore Sewing Machines
I read on internet different sewing machine model part can interchange with one another does anyone know what model interchanges with Kenmore 8 Stitch Sewing Machine Model 158 13450 and does anyone know...
A sewing machine technician may be able to help determine who actually made the machine. The problem is, Sears negotiated with various companies to make Kenmore products and Sears frequently changed manufacturers. I believe Janome made some Kenmore sewing machines but during what period and for how long is questionable.
You can try searching for:
Make Model parts
and see what comes up.
Feb 27, 2018 | Kenmore Sewing Machines
Same sewing machine but different model nos.!??
Don
I looked for you and the only differance is one was made a year before the other one! They have the same features and are both good machines!
Please rate this response and help keep this area FREE
Thank You!
Jan 17, 2009 | Kenmore 15343
Sewing Machines Logo
623 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
