Question about Dishwashers
Whirlpool dishwasher model DU920PFGB3 WILL NOT DRAIN
5 Suggested Answers
SOURCE: whirlpool drain problem
there is a check valve on the drain that gets cloged with food
take out the drain line and clear the clog
Posted on Oct 19, 2008
Karthik316
  • 187 Answers
SOURCE: Dishwasher won't drain
Hi,,
check out this link
http://www.cookshomeappliance.com/dishwasher_troubeshooting.htm
please rate my suggestion..thank u
Posted on Apr 12, 2009
TheMazz
  • 78 Answers
SOURCE: whirlpool dishwasher won't drain? Model#DU5000xw
When it is suppose to be draining, do you hear the pump running.
If not, then the pump or controller/timer is bad. If the controller is sending power to the pump and the pump doesn't run, it's the pump. If no power is getting to the pump, then the controller is bad.
You'll need a voltmeter and know-how to diagnose this electrical problem. This is high-voltage power with water in the area. So please don't try to use a voltmeter unless you are confident of your skills.
If you do hear the pump, then the drain valve (solenoid) is the problem.
The solenoid valve and the pump are all underneath the unit. Accessibility from the front, bottom panel.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Posted on Oct 13, 2009
rylee_smith
  • 8619 Answers
SOURCE: dishwasher washes dishes but does not drain...I
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 03, 2009
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Where is the drain located on the dishwasher model DU930PWSQO
The drain is in the bottom of the unit, right in the middle. You can find helpful information for your Whirlpool dishwasher here, including pictures, videos, maintenance, repair tips, troubleshooting guides and parts! My DU930PWSQ0 Model Overview from PartSelect com Good luck!
Feb 20, 2015 | Whirlpool Dishwashers
How do I replace a check valve in Whirlpool dishwasher model #WDT710PAYM5
The drain check valve is in the first part on your drain hose, the part attached to the drain pump. You have to remove the dishwasher from the cabinet . you will see the drain hose on the left side of the dishwasher. It is a whitish opaque plastic tube. Detach it from the pump and from the drain extension, a pan may be needed to catch remaining water. Carefully remove the loop from the plastic fill channel. Reinstall in the reverse order
Feb 08, 2015 | Whirlpool Dishwashers
Whirlpool du810
There should be a check valve in the drain hose to prevent that.
Is the sink drain clogged?
Link to video showing how to replace the drain hose and check valve. Dishwasher Repair Replacing the Drain Hose and Check Valve Whirlpool...
DU801 is not the complete model number. Find the complete model number. It should be just inside the door on the right side of the tub.
Go to sears parts direct. And enter your model number and find the part number for the drain hose of your dishwasher. The number in the video may be the correct one.
Link to searspartsdirect.
http://www.searspartsdirect.com/
Sep 06, 2014 | Whirlpool Dishwashers
Whirlpoool model du920pfgb3--touch pad is not responding and no lights or nothing are on??
Control panel. Try to push cancel button to see if it resets.if not google it and they will walk you through it.
Mar 28, 2013 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dishwasher does not drain. Wash arm operates correctly
Check the drain hose under your sink make sure its not crushed or kinked if you have a garbage disposal the hose should go up into it at a 90 degree angle if not 180 degrees into your sink drain line
Jul 25, 2012 | Whirlpool Dishwashers
Whirlpool drain problem
Oct 07, 2008 | Dishwashers
Did not drain after wash
My Whirlpool dishwasher model no. DU960PWKQ1 will not drain after wash. Dismantled impeller/strainer and there were no clogs.Drainline is clear.
I think motor is reversible, so there is no drain valve? HELP ME PLEASE.
Jan 13, 2008 | Whirlpool DU960PW Dishwasher
Dishwashers Logo
75 people viewed this question
Top Dishwashers Experts
