Question about GE JVM1860 Microwave Oven
Light does not work inside - GE JVM1860 Microwave Oven
  • GE Master
  • 9,086 Answers
You can download GE owner's manuals and installation instructions here.
If you need further help, please let
us know your full model number.
Posted on Sep 08, 2010
Sylvania model SR 11092G only inside light works panel lights does not work
I would check the primary and secondary door switches to make sure the contacts are closing when the door is closed.
You could have an issue with the power supply to the control panel. Check to see if there are any blown fuses on the circuit board. If there are, it would probably be best to have a technician repair it, as something else on the board probably caused the fuse to blow.
May 10, 2016 | Microwave Ovens
No key's work. Display and inside light is working
The Keypad is either faulty, or disconnected. Open the case, and remove the screws, holding the outer shell on. Inside, there should be a small board that covers the Keypad. Check to see if there is a ribbon cable, or some other type of connection going from the board to another part of the microwave. If all of the wires are connected, then you will probably need to replace the keypad.
Jan 26, 2008 | LG LMVM1955 Microwave Oven
Microwave light comes on but no power
If the light works what does not work? Some of these have a safety switch embedded in the door opening (have to get at it from inside the unit) that will prevent unit from cooking and not allow the table inside to rotate.
Its there to prevent the unit from being used if door is open but it sometimes either fails or gets out of position.
Dec 12, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
My mircowave oven just stop working.the lights are on all the electric stuff works,just on the inside where you put the food lights ont work and its not turning
I will bet you have blow a fuse. they are on the inside. this can be fixed at home. if you would like further help contact me . DFD
Apr 15, 2009 | Microwave Ovens
No light inside of microwave
I hape that's .9 cubic feet, cause it it is 9 cubic feet that is on heckuva microwave!!!. Anyways, did the light once work? or are you curious if it supposed to have a light. If the light once worked, replace the bulb...
Mar 03, 2009 | Emerson Black Microwave Oven
Ge spacemaker
remove the front vent cover above the door - light is inside
Jan 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave works for a few seconds and then the lights and turn table inside shuts off.
hi the light and turntable work of a common relay located on main pc board.relay probably dry jointed or sticky or check switches behind door catches
Feb 27, 2007 | Maytag MMV5000 Microwave Oven
Where is the light bulb located?
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
Nov 03, 2006 | LG LRMM1430 Microwave Oven
GE JVM1860 Microwave Oven Logo
42 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
