Question about Samsung 24 in. DB5710DT Stainless Steel Built-in Dishwasher
New SAMSUNG DMT300 series Leakage Error upon 1st run cycle unit it is disconected and water supply has been turned off as per instruction manual.
I seem to be having this same problem... Did you ever find the solution?
Posted on Jul 10, 2011
    New Friend:
  • 4 Answers
The oem drain hose is very brittle, and will crack if bent. This unit has a leak sensor in the pan that may be detecting a leak in that hose if it was manhandled during installation. Put it on its face, remove the white access cover in the bottom, and check the entire length of the drain hose and the connection to the drain pump. 6 feet of hose is routed around and up the side to create an air gap. I had to replace mine with 12 feet of braided pvc tubing because it cracked in 5 places just from pulling it out to clean behind it.
Posted on Nov 25, 2013
Just bought this dishwasher water is connected correctly as per manual though after 1 min into cycle E10 error
Hi, check and make sure you have the water supply turned on full to the dishwasher as some times folk don't turn the pressure on full and also make sure you don't have any kinks in the supply pipe . If the water supply is ok and the unit has got warranty call them out.
Feb 14, 2016 | Washing Machines
Tip
Error codes
Samsung Washer Fault Codes
4E WATER SUPPLY ERROR Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
5E WATER DRAIN ERROR 5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drainerror can be cleared by turning POWER SW OFF and back ON.
oE OVER-FLOW ERROR Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
UE UNBALANCE ERROR Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
HE WATER HEATER ERROR HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
1 E WATER PRESSURE SWITCH ERROR * Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is aPRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
cE ABNORMAL WATER TEMPERATURE ERROR e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
11 E WATER LEAKAGE ERROR Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
tE THERMISTOR ERROR This error occurs when the Thermistor circuit is abnormal or a voltage of O.2v or below or, 4.5v and over is detected. This error can be cleared by POWER switch OFF.
3E MOTOR RESTRICTION ERROR Hall Sensor is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error isdisplayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
8E OVER CURRENT ERROR IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
on Apr 14, 2015 | Washing Machines
How to return temp set to programme norm
PDF]Washing Machine - Samsung
www.samsung.com/us/pdf/wf218_manual.pdf
Samsung Electronicsto read this manual to take full advantage of your Washer's many benefits and ...Warnings and Important Safety Instructions in this manual do not cover all possible conditions and ..... per hose and install each fill hose to the water valve. ... Press the button repeatedly to cycle through the different water temperature options.
[PDF]User Manual - Indesit
Jan 16, 2016 | Washing Machines
What causes a Samsung dishwasher to flash heavy and smart auto on control panel
Hello. The lights you describe are an error code that means over-level filling (overflow condition) and/or the leakage sensor underneath has detected water. You need to check underneath the unit for any moisture. There is a leakage sensor located at the center of the base, underneath the unit. If it detects water, it will notify the main board which will stop the unit until the condition is cleared.
Aug 02, 2015 | Samsung Dishwashers
Heavy light flashing
Heavy Light flashing indicates leakage error.
The leakage sensor on the bottom cover of the unit is detecting water in the bottom of the dishwasher. Possible parts that could be the issue are as follows: Hose Connections, sump and tub assembly, drain pump or just simply the main PCB.
tip the unit in its back and remove the bottom cover. disconnect the leakage sensor and inspect the inside of the unit carefully for ANY water leaks. Most of the time its a mouse chewing holes in the tubing for water. Otherwise check carefully and you will see the leak.
Mar 23, 2014 | Samsung DW80F600 24" Black Built-In...
How do I reset a samsung dmt300 dishwasher
i have a samsung DMT300 Series. The heavy light keeps blinking. How do I reset it? It was leaking water and I believe we fixed it. What can I do?
Sep 12, 2012 | Samsung DMT300RFW Builtin Dishwasher
High Water Level ErrorSamsung DMT300
The parts mentioned, 8058475/SWITCH, PRESSURE and 8058500/HOSE are Asko parts. Samsung should have their own equivalent parts, but the Asko parts should work as well... I think the Samsung parts would be less expensive?
May 13, 2012 | Samsung Dishwashers
Samsung Dishwasher (DMR57LFS): Error code oE. Fills...fills some more...then drains.
Samsung Dishwasher 0E Error - We had other appliances on that circuit. We believe when those appliances were turned on it created an undervoltage condition in the dishwasher, causing another sensor to send the high level error code 0E. We believe this is the problem because it only started after we added the new hot water dispenser on the same circuit. The problem went away when we leave it off for the whole dishwasher cycle. I'm guessing it could also be caused by brown-outs and other large electrical loads cycling in the same household. That's the theory anyway. The folks who sold us the dishwasher suggested turning off the breaker, to reset the computer. Good idea, but not for our particular case.
Nov 14, 2011 | Samsung DMR57LFS Stainless Steel Builtin...
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
4. UNBALANCE ERROR - Display shows UE.
5. WATER HEATER ERROR - Display shows HE, HE1.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
8. WATER LEAKAGE ERROR - Display shows 11 E.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
New Royal espresso machine
Run hot water cycle to ventilate machine.
Mar 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
Samsung 24 in. DB5710DT Stainless Steel Built-in Dishwasher Logo
1,020 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
