Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool model GD22DQ. Water continues to leak from the water dispenser. Should I replace the water valve or what appears to be a solenoid switch in the door ? Does the model water valve feed the water dispenser and ice maker independently, the ice maker is working fine. What are your thoughts ?? thanks
  • jfdenob Sep 08, 2010
    I paid $6.00 for this answer ?? You are kidding me ?? Please refund my money. Thank you.
  • Whirlpool Master
  • 1,711 Answers
All you need is to remove the solenoid valve located on the door above despencer.
First you should try to open it and clean it since by 85 % you can use it again since it is kept open by dirt deposit on the solenoid pole rubber head. Try also to tent litle bit the spring to be more strong again.
All these parts it will be very easily recognise if you just open the valve.
Their is a vry small posibility that the valve can not be fixed so you will have to replaced it. Of course if you like what we call clean jop you can replace it from the first place to have 100 % results.
The solenoid valve located on the back outside part of the fridge is a comon valve which as you have mention feed both ice and water despencer it is ok since you have mention that ice maker works fine.
Good luck
Posted on Sep 08, 2010
  • Whirlpool Master
  • 19,396 Answers
Hi.
First I suggest defrosting the unit completely. Sometimes leaks may be caused by blockage due to water frozen in the water lines to dispenser.
If that does not work, then repair is done taking apart the dispenser, finding the leak and replacing the faulty part.
Here you get all diagrams and parts for your appliance.
  • Ginko
    Ginko Sep 08, 2010
    I was not kidding you. Water freezing inside water lines can cause a leak. That is first step in troubleshooting.
    I was waiting for you performing what suggested and getting back to me to keep troubleshooting further, I was not asking for a sarcastic answer.
  • Ginko
    Ginko Sep 08, 2010
    Regarding your question"Should I replace the water valve or what appears to be a solenoid switch in the door"
    You test both using your multimeter set on impedance. You disconnect or cut terminals and read Ohms at switch and at valve terminals. If there is no continuity on either one , replace it. The valve may also be mechanically defective and stuck in close or open position. That is far less common than an open valve solenoid (the one inside the valve).
    Naturally before doing all that you need to ensure that there is no leak caused by ice or broken line. Defrost was part of the procedure. Since it takes time the step is suggested before any further troubleshooting.
    Lines can also be defrosted using an hairdryer, but some users did not listen raccomandation of keeping the dryer on Cold and damaged the plastic parts. For this reason I suggest full defrost.
    Goodbye
    Ginko.
My "Whirlpool Gold" Refrigerator's interior water dispenser was dripping pretty badly. I just replaced the inlet valve and the drip is MUCH slower but it's still there (1 drip every ~10 minutes). Wha
Perhaps some air bubbles were trapped in the water line during the repair. Try running water thru the line for a good amount of time and that may help to relieve the line of any air bubbles.
Jan 26, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
JennAir JSD2789GES ice maker /water dispenser
if the water is stored in a container matrix in the fridge (to cool it down b4 dispensing) it may have frozen up. best give the unit a complete defrost to see if this is occuring, if so the thermistors may be faulty.
Jul 07, 2007 | Maytag MZD2665HE Side by Side Refrigerator
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water not dispensing, but icemaker is working
Hi and welcome to FixYa, I am Kelly.
The 2 most probably suspects are the micro-switch at the dispenser and the inlet water valve in the bottom rear of the unit.
Here is a manual that will help you:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
See page 23 for accessing the micro-switch
See this link for water function: (Bottom of the page l;ast step)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Image of inlet water valve in the bottom rear of your unit.
http://www.american-appliance.com/images/image_data/dual_water_valve_small.jpg
These solenoids must have continuity across the terminals.
If you have continuity you can try to reverse the 2 power connectors on them and press the water function in the door. Mind you if you get water in the icemaker by pressing the water dispenser actuator the micro-switch is good and the solenoid is bad. Just make sure to re-connect the wiring correctly on the 2 solenoids. Additionally use a rag to remove the excess water from the ice-maker.
Thanks for choosing FixYa,
Kelly
Jun 19, 2011 | Kenmore Side by Side Refrigerator
My whirlpool stopped making ice cubes , water dispenser is o.k. and water to ice cube pan (rubber tube) won't stop running (leaking)
You are going to have to check the water solenoid to see if it is operating correctly. The solenoid operates from the AC power through a micro switch on the rotating cam. When the switch operates the solenoid is jerked out and allows water to flow. When the switch opens (timed to fill up the ice tray) spring pressure snaps the solenoid shut blocking the water flow. If the solenoid valve sticks in the open or partially open position, it allows water to leak by.
Jan 09, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser leaking dispenses ok, but does not always shut off fully resulting in a slow drip. Like a dripping tap might be just a washer?
you have a faulty water valved solenoid. when you actuate the water lever, the solenoid opens, to allow water flow, then closes to stop it. When you continue to get a dripping before or after, its because the solenoid is not closing completely. Only resolution is to replace the water valve.
Mar 26, 2010 | Freezers
The cold water dispenser in my whirlpool refrigerator stopped dispensing water about 2 years ago. Recently it just started dispensing water and does not shut of. I had to close the valve to the water and...
Hi copy;
You may like to try the Water Valve (Solenoid) sounds like it may had stuck once now has become free and stayed open allowing too continually flow. It is behind fridge where the mains water is connected into fridge... Cheers
Mar 16, 2010 | Whirlpool GS5SHAXN Side by Side...
Water dispenser is leaking!
The water is controlled by a solenoid valve. If it is leaking, the valve will need to be replaced.
Jan 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
100 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
