Question about Avermedia Office Equipment & Supplies
Our new document cameras are having a pass-through issue. Why do the cameras need to be powered on when the teachers are projecting from their laptops? Also, we are having an issue with documents being very fuzzy in the corners and around the edges.
mohanchennai
  • 490 Answers
SOURCE: How to get rid of a black strip (1") on the leading edge of scanned documents?
You must be using Auto contrast/brightness. Change to manual, try one or two scans changing the brightness tab moving left or right and choose desire output quality. Remember the settings for that set of documents. The brightness will vary depending upon data (foreground) and noise (background). For a different set of docs you may need to adjust the settings slightly.
S. Mohan
Posted on Dec 02, 2007
honey2509
  • 146 Answers
SOURCE: Passing PCL code from Word document
All PCL Command Sequences begin with the escape character (an ASCII control code with a hex value of 1Bh, 27 decimal) and end with the first upper case letter (or "=" note: "@" is considered an uppercase letter). In between there is either nothing (the PCL command is just the escape and a single upper case letter) or a set of one or two characters and often a numerical value. The single character commands are listed at the end of the "Decoded PCL commands" table below. The first non-uppercase character after the escape will be a symbol between "!" and "\" (most commonly one of %,&,( or *) which is called the "parameter." After the parameter there is normally a lower case letter called the "group." After this there may be a numeric value. If no value is present, the value is assumed to be zero. Finally the ending uppercase letter is called the "command." See Examples, Tutorials below for some samples of PCL commands and the Decoded commands List for detailed information. Note that these use the text "Ec" to mean the escape character. Since the escape character is not printable, it is very hard to convey in human readable text. Common abreviations are Esc, Ec, [], or <-. See the ASCII page for more information on the codes. That page also allows you to convert between hex, decimal or ASCII codes. The form below can be used to find english descriptions of PCL commands. Just paste the PCL into the box, if you use "Ec" or "esc" to mean the escape character, press the "Ec and esc
i hope this will work for you
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 15, 2008
  • 2072 Answers
SOURCE: Error Message 39,012.40:54812
Not much to do with that code, I will provide the documentation..
The troubleshooting table lists parts and wiring referenced in the troubleshooting procedure.
Table 1. 39,011.40 and 39, 012.40 Troubleshooting Reference Table Applicable Parts
Wiring and Plug/Jack References
Document Feeder, PL 1.0
arrwup.gif Troubleshooting Procedure Table 2. DADF Subsystem Faults Troubleshooting Procedure Step
Questions or Actions
Yes
No
Cycle system power and retest.
Does this correct the problem?
Complete.
Go to Step 2.
Replace the DADF ( REP 1.0.15).
Complete.
Posted on Mar 12, 2008
SOURCE: I need Ml570 g2 documentation
I want to know what the power Consumption does Ml 570 G2 takes
Posted on Jul 23, 2008
713printech
  • 32 Answers
SOURCE: Scan views fine; prints fuzzy
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Posted on Nov 19, 2008
How do i connect my studio projects C1 condenser to my mac?I connected it with a cord that has a canon to USB into my garage Band and it doesn't work
You need to apply phantom power to the mic . Make sure the USB port is supplying the voltage. Not all USB ports pass power.
Oct 29, 2014 | Studio Projects C1 Condenser Microphone
Tip
Using a Document Camera in the class room
There are times in a classroom when using a regular projector or transparency projector just aren't the right tools for the job. In these cases you might consider using a document camera to project a paper on to a screen. The main benefit for this method of presentation is when you are presenting something that you will be drawing on, but there are also other benefits that it can be used for.
There are many features on document cameras that many beginning users don't know about or take advantage of. Taking advantage of the features can make you a better presenter and a better teacher.
Document cameras are able to be used as a live camera. If you have students making a lot of presentations and if your document camera has a swivel head you can use it to project the student on to the board. This will make it easier for students in the back of the room to see the presenting student.
Using the document camera as a live camera can have more benefits than just projecting on the screen. Most document cameras have the ability to capture images, this can be useful for documenting a students progress and projects. It can also be used to show parents how their child is doing in school at parent teacher conferences.
Some students I have found have a fear of presenting and prefer to record themselves and play the video to the class. With the document camera you can record the students presentation and then play it back in class.
It is unavoidable that occasionally students will miss classes and it can be very difficult for them to catch back up especially in math and science courses. Using a document camera you can record your lessons and create short videos that explain concepts just as it was presented in class. These videos can be useful in catching up students because they will see the video just as if they had been in class.
A side from helping students to success in class document cameras can be used to engage students in class. In social studies a blank map can be placed under the camera and projected on a white board, students can be called up to write on the board. The same can be done by projecting lined paper so they can write straight, or the math equations to be answered on the board.
Using a document camera in a classroom the options are endless. There are hundreds of things that can be done and there are always more to be discovered.
on Feb 10, 2014 | Office Equipment & Supplies
Chords needed for elmo 400af
You are a teacher, and you don't know the difference between a chord and a cord ? Amazing. I think anyway you mean a lead - the one you require has a plug on one end to fit the projector, and a plug on the other to fit the camera. Look in the respective manuals.
Jul 17, 2017 | Elmo Projectors Elmo Ev-400 Af Video...
My computer teacher gave me his camera for my pc but he did not have the instruction book but my assignment is to search for the instructuions. I looked everywhere on the camera but there is no model...
You can try going to:
http://www.logitech.com/en-us/support-downloads?selectedcrid=435
Try option 1 or 3.
I hope that you find what you need, and pass the assignment.
Good luck.
Aug 01, 2011 | Computers & Internet
I know how to cut past but dont know how to put where my school wants to so i can sent it to them
Most school project and assignments are produced as word documents.
You need to open a blank word document and paste the information into this word document.
You need to add your own words and not use all the information and material from a computer or Internet source. The teacher can recognize copied material from internet sources that are not your own words.
The finished word document can be printed out or copied to a CD etc. as required by your teacher.
Oct 23, 2009 | HP Pavilion dv6000z Notebook
Camera wont turn on
  1. Step one: Reset the camera
    1. If you have an optional memory card installed, remove it. (Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.)
    2. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
    3. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
    4. After verifying that the camera works without an optional memory card, reinsert the card, if you have one.
    Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
    • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
    • If the is not resolved , continue with the next step.
    Step two: Check for damage or corrosion on the batteries
    1. Open the Battery/Memory card door on the camera.
    2. Remove the batteries.
    3. If the batteries are damaged or show corrosion, replace the batteries.
    Step three: Recharge the batteries
    1. Recharge the batteries or replace the batteries if they are damaged or will not charge.
    2. Try turning the camera on after the batteries are fully charged or have been replaced.
    Step four: Ensure the batteries are installed correctly
    1. Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
    2. Try turning the camera on.
    Step five: Turn on the camera without the memory card
    2. Remove the batteries and optional memory card from the camera.
    3. Wait 15 seconds.
    4. Re-insert the batteries into the camera, but not the memory card.
    5. Try turning the camera on.
      • If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
      WARNING: Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
    Step six: Connect the camera to the optional AC power supply
    1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
    Step seven: Service the camera If the camera still will not turn on, service the camera. Cause The following conditions can cause the camera to not turn on:
    • Improperly formatted memory card - memory cards should be formatted in the camera they are going to be used in
    • Corrupt images on the memory card
    • More than 300 pictures on a memory card
    • Damaged batteries
    • Dead batteries
    • Incorrectly installed batteries
    • Damaged camera
Jul 19, 2009 | Leica C-Lux 1 Digital Camera
Trying to clear memory on HP #D1420
You need to clear the print queue in the printer properties.
go to start >printers and faxes > double click on your printer.
click on the word printer (on the upper left corner),when the window pops up. then scroll down to cancel all documents. This will clear the print queue.
Afterwards, power off the printer and the computer. wait 30 seconds, power up the printer, wait 30 seconds, then power on the computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 19, 2009 | HP PSC 2410 All-In-One InkJet Printer
Teacher Tools Elmo TT-02S
check the 2 little switches on the back it is possible that they are in the wrong position. for a pc or video projector the switches have to be in RGB.Check those switches and turn it back on .That is most likely your problem
Dec 20, 2008 | Elmo Projectors TT-02U Camcorder
I have an X3 Infocus and it apparently needs a new power cord. The teacher using it reports that if you even touch the cord slightly, the picture you are projecting turn pink. I need to know where I can...
it doesn't seem like the power cord, it seems more like the computer (vga) cord. either way, the pinkness is the resolution and inputs changing. make sure it's on computer and not component.
Aug 21, 2008 | InFocus Proxima UltraLight X350 Multimedia...
Top Avermedia Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Avermedia Office Equipment and Supply Expert? Answer questions, earn points and help others
