Question about Bosch Nexxt 300 Series WFMC2201UC
I moved the washer from one state to another; hooked up the washer and it now makes a "high pitch whirl/noise" when on spin. Is this a problem?
  • 1,531 Answers
I will assume the noise is happening when you have water coming inot the machine.There may be a chance the water pressure is to high.you may also need to replace the water inlet valves.
Posted on Sep 08, 2010
  • seth adams Sep 08, 2010
    did you use the the shipping bolts when you relocated the machine.if there is no real bad shaking or vibration when spinning then there should be no operational problems with your machine
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
How do I fix a high pitch noise when spinning?
If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings.
Jan 28, 2011 | Asko W6222 Top Load Washer
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Feb 24, 2008 | GE WPXH214A Front Load Washer
Whining noise, only in rinse and spin cycle, sounds awful.
Check the pump to make sure there isn't something stuck in it.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
Bosch Nexxt 300 Series WFMC2201UC Logo
131 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
