Question about JVC TH-C50 System
SUBWOOFER WON'T TURN ON - JVC TH-C50 System
  • 158 Answers
Hello the most common reason for those subs not turning on is the din jack on the back of the sub where the 7 pin cable plugs in is worn --to confirm simply wiggle it while the dvd is on it will pop and possibly startle you but 9times out of 10 its just the jack
Posted on Sep 09, 2010
Fuse replacement
The fuse is integrated in hte AC socket. You'll need a small screw driver to pry up the part that talks about the power requirements. Check the online manuals for more details.
Aug 24, 2013 | PSB Alpha Sub Zero Subwoofer
Button standby
The receiver is in protect mode, most likely due to a damaged amplifier. This protect mode, keeps the unit from turning on and causing further damage to itself and/or your speaker system. For more information, please visit my website at audioserviceclinic.com. Thank you.
Jul 27, 2013 | LG Lsb316 Sound Bar With Wireless...
The subwoofer SP-PWM505 won't turn on.
Make sure its not set to Auto. Also check for a fuse in the back. Unplug the amp side and with the sub plugged in touch the RCA. You should hear noise from sub. Try this last. Some may say this is not good for the sub. Im in the business and never have seen it cause a problem
Jun 18, 2013 | JVC SP-PW100 Subwoofer
Subwoofer wont play!!
first clean your board.ok.....same problem......?remove chargin connector
Jun 14, 2013 | Audio Players & Recorders
Why won't my powered subwoofer turn on? It's not
Have you check if the plug is good on it?
Dec 03, 2012 | Audio Players & Recorders
8 INCH MTX ROAD THUNDER SUBWOOFER WON'T WORK NO SOUND NO NOTHING
has it ever worked, if so did you ever use it in the cold because in the cold it is possible for the wiring inside the speaker to crack and break
Oct 29, 2012 | Velodyne CT-80 Subwoofer
Dpx-u5120 dosent show subwoofer option in function mode , how to fix it ?
I manage to slove to my DPX-U5120 Subwoofer level adjustment. In STANDBY mode, Press the Main Volume button and turn to Setting, turn until you find the SW Preout, Swith to normal mode, its won't work if u switch to REAR
Go back to CD/USB Mode, Then Press the Main Volume and find Audio Adjustment and now u can find the Subwoofer Level , Sub Phrase and Sub LPF adjustment.. Um Glad i found this and Happy Setting
Mar 22, 2012 | Car Audio & Video
Describe your Venue SUB10 Subwoofer Problem: The subwoofer won't turn on at all. The red light doesn't even come on. Could it be the fuse in the subwoofer? If so, where is the fuse located?
You can remove the screw near the volume knob and the screw near the on/off switch - then slide out the amp remove the black and white wire - then check the fuse - if its blown look for we repair amps - ebay - if its good then it probably still needs work - it should turn red when plugged in and no signal and green when signal is present - which means amp is on.
Sep 11, 2011 | JBL Venue SUB10 Subwoofer
I have a Harmon Kardon HK3490 receiver which has an input for a powered subwoofer. Next to the subwoofer output is a "link switch" which turns on the subwoofer when I turn on the stereo. What...
Connect the Subwoofer Trigger Output for each subwoofer to thecorresponding trigger input on its amplifier. This enables the subwoofer toturn on or off together with the HK 3490. To further conserve energy,when the trigger connection is made, turn the Subwoofer Link Switch onto turn the subwoofer off when the corresponding pair of main speakersare not being used, such as during muting, when headphones are beingused, or when the main speakers are turned off using the Speaker 1/2 switch
Apr 05, 2011 | Denon AVR-687
Help!
1 ounce of gasoline and a match should fix the problem.....if not at least you'll be left with the piece of mind the you have won the battle .....lol
Apr 15, 2008 | Audio Players & Recorders
JVC TH-C50 System Logo
263 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
