I have a Goodmans DAB ClockRadio (GCR1930DAB) - looks like a neat little beehive. After only about 3 years it's on the blink - won't tune, the LED display flickers whenever it tries, turning off won't solve it. Any ideas?
    Problem Solver:
  • 11 Answers
It's probably too late for you now, but I have just fixed one of these given to me with the same fault. It was due to an electrolytic capacitor in the power supply which had gone short circuit. Frankly, it's a bad design and far too small to be man enough for its position in the circuit.
Posted on Aug 13, 2011
  • madbass Sep 19, 2011
    Hi davewi11
    I have the same problem...can you give me an idea on how to fix it !
    Thanks
  • davewi11 Sep 19, 2011
    Remove 2 screws in base and 2 screws at top and lift off the top rear cover. Leave the speaker wires connected. Remove 6 screws in the printed board and lift it up over the mains transformer, separating it from the top front cover which will also come off the base, taking care not to break any wires. There are two ribbon cables to the front cover which can be unplugged but need not be.
    The capacitor in question is C405 above a row of diodes. Unsolder this and replace with a capacitor of the same or higher capacitance and voltage ratings, negative to the cross-hatched side of the printed symbol. I bodged on an axial wire-ended 2500uF 25V on the other side of the board above the transformer, soldering it to the wire ends of nearby diodes rather than the empty pads themselves to avoid the weight of the capacitor pulling the pads off the board. It is worth checking that all the diodes are soldered properly.
    When putting everything back, notice the buttons which have dropped off the slide switches are not symmetrical; the flanges are wider to the rear of the radio. Make sure the aerial wire goes into its slot in the base.
Goodmans gtvl26w17hdf
first and foremost,do you know how to operate your universal remote control?refer to it`s manual...look for that unit`s brand if it is also included to the unit that this remote control can command.if it included,look for the codes below it and try to follow the steps/methode of using this codes.example;:; 1-press the search button for 3 seconds until the led stop blinking or start to blink 2-press the unit(tv`s,dvd,ref,a/c,etc...) 3-put the 3 or 4 codes ,4- etc....
Jan 31, 2014 | Televison & Video
Goodman furnace won't run on generator
I work on Goodmans and I vaguely remember something like this.Be sure the neutral (white wire) and the green ground are the same potential. They both tie into the ground bus at the generator.
Mar 04, 2018 | Heating & Cooling
What is the code for a goodmans (portible) tv on a
I recommend trying the auto-code search to find one that works for your TV. This will search through every TV code it knows, and if none work, unfortunately it cannot be taught new codes.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Jul 21, 2009 | Innovage Jumbo Remote Control
No instructions for a goodmans remote
there are a few numbers for a goodmans tv (the codes are for gemini 6 in one)they all enter 3 digits
002 004 009 027 028 051 068 093 111 115 127 153 169 171
hope that helps
May 02, 2009 | Gemini 1 Device Universal Television...
Sony kv-27s42 no picture no sound can here relay click
I will look up your specific model to be sure, but teh 3 blinks usually mean a power supply problem. Stay tuned for more...
Dan
Aug 23, 2008 | Sony KV-27S42 27" TV
Buzzer instead of radio
I have this radio too and from what I have read in a review on amazon suggests alarm does not tune to DAB only FM - very annoying! Contacted Goodman customer care and they suggested it was a problem with a component but maybe it is just the design.
Mar 16, 2008 | Audio Players & Recorders
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
132 people viewed this question
 Grubhead
Grubhead
