Question about IBM ThinkCentre M52 8113 - P4 551 3.4 GHz (811342U) PC Desktop
My bios is in german, all i need is to change my boot sequence!
  • 3 Answers
Well, powerof your PC. Unplug all power cable. Then open the cabinet cover and find a battery in the motherboard. If you find it then remove it from motherboard and give one minute to resotre the bios. Set battery on motherboar with acurate polarity. You are done.
Posted on Sep 08, 2010
Cd start server primergy b210 fujitsu siemens
In order to change the boot drive you have to change the boot settings in BIOS, or sometimes you can get a separate boot menu which allows you to change this setting on a one-off basis. During the boot sequence you need to press the "F12" button during the POST testing to bring up the boot menu if one is available, otherwise you need to press the "Del" or "F2" button during the POST process to bring up the Bios screens. Navigate to the BOOT option and alter the boot sequence, save the settings, exit BIOS and reboot.
Feb 18, 2014 | HP Compaq ProLiant ML110 G4 Server
I have acer aspire 3000+ and cant change bios setup to boot first from cd rom and erecovery doesnt work
Why can't you change the bios setup to change the boot order or boot sequence?
Also you can change the boot order or boot sequence temporarily by just rebooting the laptop then watch the screen for which key it says to hit to change the boot sequence or boot order, then hit that key when you see the message.
May 08, 2012 | Computers & Internet
Winfast boot sequence problem
Boot sequence problem? You set the boot sequence permanently in the Bios or System Setup. Normally when you boot the system the screen will tell you what key to hit to get into the Bios or Systems Setup.
You can set the boot sequence temporarily (just for the current boot cycle) by watching the screen when you boot and it will tell you which key to hit to change the boot sequence or boot order.
May 07, 2012 | ASUS Computers & Internet
I am unable to open bios. Actually I wanted to change the boot sequence for HARDDISK TO CDROM but could not open bios. What to do?
Hi ranjanaghosa,
I see that you need to change the Boot Sequence on you Thinkcentre M55e but could not get in BIOS right.
to be able to change Boot sequence you can also try on tapping f12 as soon as you power the machine ON untill you get the Boot Menu you can also change boot sequence from there.
To get in the BIOS on a desktop you need to keep on tapping F1 as soon as you power the computer ON, but if still this does not work you can try Tapping on the Delete key to get in the BIOS, getting in the BIOS depends on the motherboard some use f1 to get in the BIOS some use Delete to get in the BIOS on desktops.
but using the F12 key can be done as well if the F1 or Delete key does not work.
I hope that this helps.
Have a nica day,
mvincentc
Jun 03, 2011 | Lenovo ThinkCentre M55e 9637 Desktop
How can I change boot sequence in Compaq Evo N410c?
You need to access your BIOS configuration. 1. To do this, shutdown your computer and boot it by pressing the power button. 2. You need to hit F10 when the computer first powers up in order to get into BIOS (Note that the key is usually different for different computers. If F10 doesnt work, try F2, F12, Delete or F9. 3. Once in the BIOS, you should find the boot sequence option.
Hope this helps!
Apr 11, 2011 | Compaq Evo N410C Notebook
How to enter in bios to boot change sequence in ProLiant ML 530
Press F10 during post boot if you have smartstart installed in the partition. If not, you need to boot from SmartStart CD.
May 08, 2010 | HP Compaq ProLiant ML530 Server
How to change boot for cd or hd
That is done in the bios.
you could also watch the boot sequencs and see if it says somthing along the lines "press F10 to change boot order"if so that is another option
If this info was useful please click
Aug 13, 2009 | Toshiba Satellite 2400-S251 Notebook
I have LG E500 and I want to instal XP. I cant make changes in bios like boot sequence, so I cant boot from cd and therefor I cant instal XP. What should I do?
I don't recommend downgrading your laptop from Vista to XP but...
According to manual, pressing F2 during boot sequence takes you to BIOS and then you can change
the order of the boot sequence in the BIOS. From the manual:
"...set passwords, change the booting order, and add new peripheral devices to the machine."
If you can't find boot sequence in BIOS setup, talk to a support rep online:
http://ca.lgservice.com/index_b2c.jsp
You may need to use a different server if not in CA.
Jul 08, 2009 | LG Computers & Internet
Need to get into bios
Dear friend for go BIOS some computers Need to preess DEL, Some Computer need to Press F1, Some Computer need to pree F2. you didnt write about your computer... One solution i have ... Press DELL+F1+F2 At starting your sustem... Here is two option to find out Boot Sequence from BIOS.... some BIOS Have Independent Boot Menu.. IN Boot menu you may see boot sequence... there you have change it. For Other Option You may go the Advanced BIOS Setting Option There you may find First boot device, Second Boot device..... Or Boot sequence.... find out your solution...
For Master And slave..setting in CD/DVD rom ..
set jumper.. near ide or sata cable... for setting as Master...
Set jumper After Master jumper... for setting as slave..
Best Regards.. sumon
Mar 27, 2009 | Computers & Internet
Boot sequence. I want to boot CD first
No,you don't need to disable quick boot,All you need to change is the boot order.But to boot from CD all you need to do is press F12 while the system is booting up.
Mar 17, 2009 | MSI 865PE Neo2-S Motherboard
Computers & Internet Logo
378 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
