Question about Microwave Ovens
The fridge I have is only 4 years old but continually freezing items. eg 2litres of milk overnight!
  • Microwave Ovens Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 10, 2010
How to freeze milk
How do you freez butter milk
Jan 07, 2014 | Microwave Ovens
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
Microwive not heatin
Ufortunately the magnetron is the most likely problem, "heats food" and is the heart of the microwave oven. If the device is five years old or more cheaper to replace the item.
Mar 04, 2012 | Sharp Microwave Ovens
Have a whirlpool microwave. Works fine for about 2 1/2 minutes then you can hear the magnetron go off. Everything else continues to work, but will not heat. After cooling down it will work again for...
magnetron tubes actually are an item which destroy themselves slowly during their
operation and have a limited life, they actually wear out, If this unit is over 4 years old
I would suspect this as the cause.
hope this helps.
Jul 03, 2011 | Microwave Ovens
I usually freeze my milk, to save daily shopping, Yesterday I bought a different make and it says on the bottle of milk 'not suitable for home freezing'? Unfortunately I put it in the freezer when...
Although this question is not really suited to FixYa, the answer is that when you thaw it the fat in the milk will separate and float to the top. It's really a quality issue rather than any health problems. You will not get sick by consuming it.
Freezability in regard to milk depends upon the fat content and how it's been homogenised within the milk, and these factors vary even within products within the same milk brand. In general, skimmed and semi-skimmed freeze best.
Jun 23, 2011 | Microwave Ovens
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
I have a Whirlpool Gold top-mount fridge (GR2SH/GR2SHM). It's about 6 years old. About a year ago the freezer started to have ice build up and water would over flow into the fridge. I defrost the...
The defrost cycle is not working. After a predetermined number of hours of compressor running time, a timer actuates the defrost cycle, which stops the compressor and turns on a heating element to melt the ice. Either the timer or heating element is not working. Also, make sure the melted ice water is actually draining and not re-freezing.
Aug 31, 2017 | Whirlpool Microwave Ovens
I have a 2 year old LEC T2856w fridge freezer and the fridge keeps freezing everything, it seems to be warmer at the top and makes a wall of ice on the back
That sounds like an a refrigeration engineer is required as if the gas pressure has dropped, it will no longer cool properly.
Mar 07, 2011 | Microwave Ovens
The fridge section freezes everything: milk, meat, etc.
Make sure thermostat is not set too high if okay then sounds like you need new stat....
Feb 22, 2011 | Microwave Ovens
I have a Teka A-FCI340 fridge/freezer. The fridge is too cold and freezes items put into it. No matter how I turn the temperature control dial it still seems to be too cold.
I had the exact same problem with the same model and mine was just 3 years old. My problems started when I defrosted the freezer. I spent 75gbp on an engineer who told me that I had probably 'spooked' the fridge when I defrosted the freezer, that this particular model of fridge wasn't designed to last longer than 2 years.
I would recommend you check the door is shutting properly (check the screws at the top, it might be just slightly out of alignment).... I turned the whole unit off for over 2 days to allow absolutely everything to defrost (both inside and on the back of it)... within 30 minutes of turning it on, the back of my fridge was already frosted over.
Engineer told me not to waste money calling them out again, and to buy another one...
Oct 17, 2010 | Microwave Ovens
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
