Question about Ovens
I was using my siemens electric grill when I noticed a part of the filament seemed to be burning. It was very bright and a little smoke was coming from it. I then turned it off and left it off for a short while. Now it won't heat up at all. Any suggestions? Any help much appreciated.
  • Ovens Master
  • 3,463 Answers
You need to fit a new element to solve the problem.
Posted on Sep 08, 2010
I have a delonghi oven. The grill element smokes violently as the element heats up. Does it need a replacement grill element?
no you dont need a new grill its just collecting fats from when you roasting and burning off when you initially heat the grill. if you use the grill more often it wont build up as much. covering the roast can reduce the saturation and perhaps a slightly lower temp will help reduce splattering.
Aug 02, 2010 | Ovens
How to clean the grill element in an electric oven, it smokes everytime i use it
have same problem with grill smoking,try barry coates method if this works to stop from happening again there should be a tray that comes with most ovens,flip this over and put on top rack,should stop this problem,then place foil on bottom of oven to catch any spills or buy another tray.. all the best tony gilchrist....
Jun 22, 2010 | DeLonghi Ovens
Do I need to preheat the oven when cooking in the iven When using as a grill the grill smokes all the time
hi, what you need to do is turn the grill on and leave it on what is happening is all the steam and fat and grease form the cooking you have done in the oven has risen and stuck on the heating element the grill uses, so open your windows and turn the grill onto its highest setting and just leave it after a while the smoke will stop.
You need to do this so that any food you cook using the grill doesnt smell of the smoke thats burning on the grill element.
Dont worry you wont do any harm to it this is a very common problem with combo ovens and grills and the same goes for microwaves with the grill feature so dont worry to much its what happens over time if you dont use the grill much.
So just switch the grill on and leave it it can take upto 20 to 30min to stop smoking but after its burned off all the grease and fat etc it will stop smoking and stop smelling so dont worry everybody who has one goes through this same problem.
let me know how you get on or if you need further assistance ok.
Its best you do this once a week or so to ensure that it dont build up to much as it can really stink the whole place out and if you cook food without burning it all off your food will taste like the smell witch believe me isnt nice, so just leave it all to burn off leave your windows and doors open and after about 20 min you should find the smoke will stop and the smell will go away.
You may find it only takes 5 to 10 min but dont worry no matter how long it takes your not doing any harm your just cleaning the element.
Dont try cleaning it with cleaning products as this can cause harm to the element and could taint any food with the cleaning product you use.
The only real help you can give is that before you turn it on to burn off the grease use a stiff hand brush and brush the element to remove all the dried on loose bits this will then make it quicker to stop smoking.
But other than that just leave it and it will sort itself out.
Jan 13, 2010 | Creda Europa E010E Electric Single Oven
Smoke and fumes coming from oven
Sounds like you need to clean the whole oven as old grease and spillages will keep on burning and smoking.
Jan 03, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Smoke comes out of grill on electric cooker
This sounds like some of the power wiring, or leads which go to the "electric" burners. the smoke is a wire based or very chemical based smell. that in it self is toxic. when it comes to something as major as this you should for your own safety contact the seller if it is under warranty. The voltages and risk or burns electrical and heat wise are not worth the risk to your person and or life and or property.
Nov 10, 2009 | Stoves 720EF Electric Double Oven
Cleaning above the grill element
I would not advise you to remove the element unless you feel competent to do so.
Best thing to do is to put the grill full on and let all the fat and grease burn itself off.
you will not hurt anything by doing this.
Make sure you have the griil door open and your house door.
Plz rate my solution.
thanks.
Dec 18, 2008 | Candy FP855 Electric Single Oven
SMEG A21X-5 Freestanding Cooker: Main oven has smoke/fumes everytime its used!
usual cause of fumes is if the grill is in the oven, when for example a roast is done, fat spits onto the grill element and the circular element and smokes. if you leave it on, the smoke will clear. some ovens have a fat guard which clips over the grill in the centre of the back panel to prevent this.
to clean glass, just use scouring pads - glass is virtually impossible to scratch
Oct 01, 2008 | Smeg Ovens
No heat?
hi there sounds like fan oven element at back, don't worry about smoke from grill is more than likley just grease burnning off element, just leave on for a min or two
Feb 29, 2008 | Bosch HBN 131560B / 131520 hot-air...
Too much smoke in the oven
really the only reason for smoke is fat on the elements especially the grill element. suspect problem may be due to what you are cooking
Jun 18, 2007 | Electrolux EOB6636X Ultrafan Electric...
Ovens Logo
64 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
