Question about Amcor AF9000E Portable Air Conditioner
We have an Amcor New Air Model AF1200E, serial #0905 0420. It has worked fine until the other day. The problem is water is flowing on to the carpet. How can this be corrected? Are there any service centers in Columbus, OH area?
4 Suggested Answers
  • 86 Answers
SOURCE: Amcor plm15keh
change thermostate switch.its means yr thermostate switch donot working.the heater running cotinusly,this is the reason for over heat.
Posted on Mar 17, 2008
SOURCE: Parts for Amcor Portable Air Conditioner
i need a new cord a nd plug for my amcore ac
Posted on Jul 22, 2011
  • 114 Answers
SOURCE: I have a portable amcor
There is no water because the compressor is not coming on and circulating refrigerant. The water comes from the moisture laden warm air blowing across the cold evaporator. If the refrigerant is not flowing there will not be any water.
Posted on Aug 02, 2011
Keurig problems
what is your model and serial num ?
Sep 02, 2017 | Coffee Makers & Espresso Machines
Filter frozen
This can typically be caused by two items, low refrigeration gas or insufficient air flow. I would shut the unit down, unplug it and let it set for a day to thaw out. Clean all the air passages and replace the filter. Plug it in and turn it back on. If it continues to freeze you probably have either low refrigeration gas or a fan that is not operating properly.
Feb 17, 2014 | Amcor Dehumidifiers
I have a portable amcor ac-model-PLM13000E that is just blowing warm air-it is not draining any water.Thanks.
Aug 02, 2011 | Amcor Heating & Cooling
My amcor air conditioner is leaking water all over the floor. I drain it and it will only last less then 24 hours till it turns off, leaks all over an needs to be drained. Help!
I figured out the problem. My Amcor portable started leaking after the fill light came on for the first time in years. After doing some research I saw that it uses the water to cool some other part of the system to evaporate out the exhaust. So I took the ******* apart and messed with things. Finally I started pouring water into different trays and noticed it would not drain down from the top tray even when running. So I removed the top part and found the drain hole. Blasted that sum ***** with some compressed air and WAMMO it works again.
-madmanmarz
Jul 06, 2011 | Amcor PLM-14000E Portable Air Conditioner
Hello, i have a AMCOR KF 9000 BTU. And was wondering where do i put the water? and why do i need water in the unit?
Unless, AMCOR has recently made a dramatic change to your model, you don't add water to the unit. Your model acts as an air conditioner and a dehumidifier, all at the same time. It evaporates the water/humidity in the room's air and exhaust it out the vent hose. There is a drain pan, that collects any un-evaporated water, but that only needs to be drained if it's full. Which rarely occurs, unless the humidity is extremely high for a long periods of time..
Hope this helped you. Please let me know. Thanks.
Jun 10, 2011 | Amcor Heating & Cooling
Can I get a circuit board for the outdoor unit? S# AOSAWSAMS181HX d42trivette@hotmail.com
yes ring up the company and order a new board. if its under warranty you can get it for free . give serial and model number
Nov 08, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Lost user manuel
Bob, you can obtain a copy of the manual for free by following the link below:
http://www.retrevo.com/support/Amcor-PLM14000E-Air-Conditioners-manual/id/12860bh732/t/2/
You may have to create an account to get the manual - but there is no fee associated with doing so.
I hope this helps!
Jun 18, 2010 | Amcor PLM-14000E Portable Air Conditioner
Amcor plm15keh
Feb 24, 2008 | Amcor PLM-14000E Portable Air Conditioner
Amcor AF9000E Portable Air Conditioner Logo
205 people viewed this question
Top Amcor Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
