Question about Ingersoll Rand 2340/2475 Electric Air Compressor Start Up Kit 32305880
Compressor wont shut off when reaches the right psi
    Novelist:
  • 205 Answers
Pressure switch bad or wired incorrectly!
Posted on Nov 14, 2010
tripletauto
  • 1450 Answers
SOURCE: Compressor will not reach the design pressure
WHAT TYPE COMPRESSOR?BRAND AND MODEL
Posted on Oct 13, 2008
ollie reece
  • 1167 Answers
SOURCE: when my compressor reaches 120 psi the safety
what is the working pressure bud
Posted on Sep 27, 2009
rockitman187
  • 2559 Answers
SOURCE: compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Posted on Jul 21, 2009
caroldon
  • 17129 Answers
SOURCE: My porter cable air compressor
The airr pressure cut off switch is not working or out of alignment. What you can do is to adjust the spring with the air pressure reading at your required pressure. Once this is done allow the air to flow so that the compressor will work again to cur off, you will have to trim once again to set it to the correct condition. If the spring assembly is not working well on pressure you can remove and reset. If the contact are dirty , the switch on may not start the compressor, in such case clean the contacts. But if you think that it is not acting responsive, the please replace the unit and do the settting as explained above.
I hope you try this out. Good day
Posted on Aug 16, 2010
puertobori
  • 7733 Answers
SOURCE: The compressor will not shut off when it reaches
The pressure controller is bad, so change it.
Posted on Oct 13, 2010
What possible causes have an air compressor shut down before reaching max pressure?
The pressure switch needs adjusting or replaced. The power cord is attached to this switch. There is an adjustment screw under the cover.
Nov 20, 2015 | Air Tools & Compressors
My porter cable pancake PSI 150 keeps running will not shut off
The compressor has a max psi setting of 150.If the pressure is not reaching this or is only stabilizing at a low pressure you have an air leak around a gasket somewhere.If it is reaching 150psi and not shutting off your pressure switch is bad.Replace it.Check your owner's manual for a part number or go to www.factoryauthorizedoutlet.com to find the part.
May 05, 2011 | Porter Cable Air Tools & Compressors
My air compressor starts right up, runs for approximately a minute, then quits. If left sitting for a minute or two, it will start again, and run for a minute, then stop. If you shut the fuel off, it...
It sounds like the compressor is reaching the max psi it can hold. At this point can you use a air tool or blower? The reason it comes back on is to keep the psi at running level. It replentishes the lost or used air.
Bruce
Mar 31, 2011 | Honda Air Tools & Compressors
My regulator broke and I just replaced it. Now the compressor doesn't act like it will automatically shut off when it reaches pressure (130 psi max). Last night it pressured up to right at 130 psi and...
Hi, my name is John. Welcome to FixYa. Look on the pressure switch and see what the max. is. I have some notes here I will have to locate them and I will post them here if you still having problems, but it sounds like you need to replace the pressure switch. Thanks for choosing FixYa...John
Nov 20, 2010 | Craftsman 33 gal Air Compressor 6 hp...
Would not pump past 90 pounds psi, now does not pump at all
Might be a switch failure. Usually the switches will have an integrated pressure switch to shut the compressor off when the holding tank reaches its max psi. When the switch starts to malfunction, it will shut the compressor off early and eventually fail due to overheating of the internal components of the switch.
Sep 23, 2010 | Air Tools & Compressors
Compressor shuts off at 60 psi will not come back on until opsi
If the pressure switch has been changed you will need to reset it if not ,then is the compressor trying to come back on but will not start untill it reaches 0 psi?
Apr 25, 2010 | Campbell Hausfeld 26 Gallon Low Rider...
Compressor shuts off before reaching max pressure
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Press. switch won't shut off motor when reaching cut-out pressure
IF THE SWITCH WILL NOT SHUT IT DOWN ITS NOT WIRED CORRECTLY, THE POINTS IN THE SWITCH ARE WELDED TOGETHER AND WONT RELEASE OR THE LINE UNDER THE SWITCH IS CLOGGED
Apr 03, 2009 | Craftsman Air Tools & Compressors
Ingersoll Rand 2340/2475 Electric Air Compressor Start Up Kit 32305880 Logo
222 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
