Question about Kenmore Dryers
I have a kenmore dryer model 76512693 with a "automatic intermittant type igniter activater gas burner" It recently stoped heating. The motor runs and although it is in timer mode it doesnt turn off. Can you help me?Chris
5 Suggested Answers
the dr
  • 447 Answers
SOURCE: No Heat on Whirlpool Gas Dryer
The timer should advance in the time dry cycles if it does, it is fine Its common for them to not in automatic cycles when there is no heat I would call for service unless you have basic gas appliance knowledge , as it is dangerous If you decide attempt i can tell you what to look for Please rate my help .....Thanks
Posted on Oct 03, 2007
  • 94 Answers
SOURCE: Kenmore Dryer Model 11063102101
Probably the timer is defective and needs replacing.
Posted on Oct 07, 2007
SOURCE: Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Posted on Jan 11, 2010
heatman101
  • 43501 Answers
SOURCE: My Kenmore model # 76512693
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Posted on Apr 26, 2011
Dryer runs but does not heat on maytag model med6000xw1
If you have a newer model with electronic ignition, check igniter by the burner, or if a pilot light ignition, obviously re-light, but possibly the gas safety interlock switch is tripped by a weak pilot flame, which causes main gas valve to stay off. Best guess, igniter element has cracked, and is simple to replace, order online.
Oct 30, 2013 | Kenmore 62602 Electric Dryer
My Kenmore model # 76512693 will not heat up
heatman101';
Apr 26, 2011 | Kenmore 73952 Gas Dryer
I have a Kenmore Elite 110.73932102, runs but will not heat at all. I have gone through the troubleshooting and still can't figure out the problem. When I turn on the dryer the igniter does not glow. I...
Did you check the igniter? You never mentioned anything about checking, or replacing the igniter. The most common cause of a no heat problem on a GAS dryer is worn or blown igniter. These appliances are equipped with a burner assembly with electronic igniters. The following link explains a little theory about how these igniters work:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know the link is for a gas range, but the burner assembly functions are nearly identical, as well as, the type igniters used.
If you are having ignition problems it is probably a simple matter of a weak or bad igniter. The burner assembly will ignite automatically as long as the gas valve, igniter coils and igniter are all functioning properly. It can take up to 90 seconds for the burner to ignite. As the igniter ages, you may experience longer ignition times.
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com pcappliancerepair.com appliancepartspros.com repairclinic.com All these sites have competitive pricing, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
If you have any questions, please post back and let me know. I hope this information is helpful to you.
Oct 08, 2010 | Kenmore 74602 Gas Dryer
How do you light the pilot light for a 70 series Kenmore dryer?
MOST modern appliances that use gas ignition (including kitchen ranges) no longer have a pilot light. These appliances are now equipped with a burner assembly with electronic igniters. The following link explains a little theory about how these igniters work:
I know the link is for a gas range, but the burner assembly functions are nearly identical, as well as, the type igniters used. If you are having ignition problems it may be a simple matter of a weak or bad igniter. The burner assembly will ignite automatically as long as the gas valve, igniter coils and igniter are all functioning properly. It can take up to 90 seconds for the burner to ignite. As the igniter ages, you may experience longer ignition times.
You can view an illustrations of your burner assembly at appliancepartspros.com, pcappliancerepair.com and searspartsdirect.com. If either of the igniter coils are determined to be defective, BOTH should be replaced at the same time. If you need assistance in troubleshooting the burner assembly components, or help identifying parts, please post back with your complete MODEL NUMBER (located on a nameplate around the door opening. I hope this information is helpful to you.
May 25, 2010 | Kenmore 700 6972 Dryer
Dryer heats intermittently clcles off heat then
Try vacuuming lint and dust out of the burner intake and exhaust ports. Hope this helps!
Dec 05, 2009 | Kenmore 73952 Gas Dryer
My kenmore dryer has the motor running but it has no heat. My clothes don't dry at all.
I've had this happen twice. It's the small flat thermal fuse and it costs about $5 online and is easy to install. Sears wants $100 to do this, maybe more now days.
Oct 29, 2009 | Kenmore 73952 Gas Dryer
My gas dryer runs but no heat.
Most gas dryers use a surface-type ignitor, a ceramic element with traces that glow to ignite the gas and yours has failed. BTW, it's helpful to give model numbers so we don't have to guess.
Aug 27, 2009 | Kenmore Dryers
Dryer heats randomly..Igniter is working.
Generally operation when cold that worsens with use indicates a component that is failing when hot. Start at the burner with the coils and work your way back to relays on the control. Sounds a lot like a bad coil on the burner. I have seen these do 2 complete loads then fail. Setting over night and cooling off will work again the same way. Intermittent conditions are a real challenge sometimes.
Eric
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
No heat
If the burner assembly is not lighting I would recommend you look into an igniter replacement. If the igniter is worn, or does not work at all, the gas safety valve will not open and you'll never get ignition. The part number is 279311.
If the burner assembly lights, then goes out after a few minutes, I would recommend you replace the gas valve solenoids. There are two of them on the burner assembly. It is recommended that you replace BOTH of them at the same time. The part numbers are 69540 and 69539. Searspartsdirect.com has an excellent illustration of your dryer. Just type in your model number and look under the "Burner Assembly" heading. The igniter is listed as item 4. The solenoids are items 13 and 14.
If you have questions, please let me know. I hope this is helpful to you.
Mar 03, 2009 | Kenmore Dryers
Kenmore 110 gas clothes dryer heats for 20 min then needs to rest for 20 mins before heating again
Cause 1Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer's heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Parts Cause 2Gas Valve Solenoid
Gas dryers have two or more gas valve solenoid coils. The gas valve solenoids open the gas valve ports to allow gas to flow into the burner assembly. If a gas valve solenoid fails, the dryer won't heat. To determine if one or more of the gas valve solenoids has failed, check the igniter. If the igniter glows and goes out but does not ignite the gas, the gas valve solenoid is defective. If one or more of the gas valve coils are defective, we recommend that you replace them as a set.
Parts Cause 3Igniter
The igniter uses heat to ignite the gas in the burner assembly. If the igniter is not working, the gas will not ignite, preventing the dryer from heating. To determine if the igniter has burned out, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Feb 16, 2018 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
