Question about EliteGroup ECS P4M800-M7(3.1) LGA775 ALL IN ONE UATX SUPPORTING 64 BIT Motherboard
Sound device does not work - EliteGroup ECS P4M800-M7(3.1) LGA775 ALL IN ONE UATX SUPPORTING 64 BIT Motherboard
  • 487 Answers
Hi, I take it you are using XP, if so to check your sound device, go to start, control panal, system, hardware then device manager. If there is a problem with your sound device it will be highlighted with a yellow ?. You can download and install a new sound driver i.e Realtrek AC97 sound driver, its free to down load from a google search.
Posted on Sep 08, 2010
My Gateway laptop says my sound device is working properly, but the sound only works if headphones or speakers are plugged into the jack. how do i fix this?
It sound like your headphone jack is the default sound device. Go to control panel > sounds > look at the devices listed. Click on the speakers that have a device connected to them. You may have two selections for speakers, but one may be tied to a sound device and the other to headphones. Highlight the sound device and click on make this device the default sound device and hit apply.
Nov 15, 2009 | Gateway M305CRV Notebook
Tip
My sound driver stopped working after working for at least a year.
Open Control Panel
open device manager
ensure that you have the proper disk to restore the sound device driver
delete sound driver
restart your computer
if the sound is not repaired, use the sound device driver disk to restore the device driver
on Jun 22, 2010 | Computers & Internet
No sound at all. device manager shows device
have you got the right software? have you used device manager to find the problem?
Jul 10, 2009 | Compaq Creative Sound Blaster PCI 128...
Button for sound on my laptop dont work
The most likely causes for this is:
External Speakers not turned on. Turn them on...
Driver for the sound device isn't installed: If you see the little speaker icon down the bottom right hand corner of your screen (near the clock), your sound card device driver is working well.
If it is not visable, the sound card device driver may or may not be working. Go into the start button, select settings (if available), then control panel, Sounds and Audio Devices.
Select the Audio tab Ensure that you have a 'default device' set.
If you get any errors when going into the sound and audio devices tab stating that you have no audio devices installed, then its most likely a driver issue. In this case, refer to your local computer shop to have the audio drivers installed.
Driver for the keyboard sound function not installed or not running. Solution: Reboot then test it. Reinstall the driver, test it.
May 20, 2009 | Acer Computers & Internet
Sound device not working
Please try to check the sound device status if its working properly thru right click My Computer icon > Properties > Hardware tab > Device Manager > (double click) Sound, Video & Game Controller OR System Device > System Speaker. also, take note of the Troubleshoot tab. If still it doesn't work, I think you have to reinstall the sound driver (from its motherboard software CD if it's built-in type). best regards
May 12, 2009 | HP Computers & Internet
Sounds and audio devices not working
Sound and audio device is not working because of the following problems
1.Problem related with sound driver
Solution: Re install the sound driver from u r motherboard CD.If u use PCI sound card install the driver software from the CD given by the vendor
2.Inorder to check u r sound driver related problem.....go to...Device manager....> audio devices.....> if there any Yellow coloured question mark on the sound device problem related with driver software.
3.May u r sound hardware is not working.....if it is on board card then add any PCI sound card and intall the software from the CD u will get the sound
Feb 21, 2009 | Microsoft Windows Vista Ultimate Edition
No sound
did you check that your pc is having sound drivers installed or not
or they are working good or currupted
here is how you can find out
go to my computer right clik it
select property
go to hardware
select device manager
here in new window you can see all installed devices
find out "sound, video and game controller"
now click + mark on leftside of it
it will drop down the list of available sound/ video devices
if you dont see any sound device then you have to install sound drivers
if you see any sound device but with yellow with it then its installed but not working properly
in that case also you need to install drivers once again
find this out
Mar 28, 2008 | Computers & Internet
Sound not coming out of speakers
I would recommend you to uninstall the sound device which is under your device manager...click start and hit run..type devmgmt.msc....then look for the sound device and unistall it..then try to reinstall it again...
Jan 04, 2008 | E-Machines eMachines Desktop PC
PROBLEM IN SOUND DEVICE
What hardware device drivers should be updated? A listing and recommendation of computer hardware device drivers that should be ... A listing of computer sound card drivers can be found on our sound card .
Issues relating to msgrv32 Resource conflict or issue; TSRs or other running programs; Sound driver or sound card issues; Onboard sound or video issue; MIDI device or codec issues
POST troubleshooting steps. Bad or failing hardware device. Connections not connected or connected properly. ... if you press the power button and nothing happens (no lights, no sound.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
66 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
