Question about GE 15.7 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White
Ice maker stalled mod. # PTS22SHSARSS - GE 15.7 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White
Ice maker is not pumping in water to make ice
check that its on and full level arm cutoff is not sticking then look at water inlet valve --and filter --
Jul 24, 2016 | Frigidaire Refrigerators
Ice maker will make ice but wiil not drop it off into the ben
Hello
you have a sensor plate that is not touching the ice or is not set to the right thickens, that sensor plate should tiger the machine to go in to dump mod.
Thanks
Jul 07, 2011 | Franklin Industries Franklin Chef FIM200...
Ice maker is not working on Mod. MFI2568AES
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Feb 14, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Ice maker does not work
magic chef mini fridge stops colding
mod#MCBR171W 1.7cu ft
Jun 30, 2010 | Whirlpool 17.6 cu. ft. Top-Freezer...
Ice maker not working mod 10653604201
heatman101
hdghd7
Jun 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Pour about 2/3 cup of water into the ice maker . Also , check the black fill hose that fill the ice maker , to make sure it is not frozen . If the ice maker dumps the cubes , then replace the water inlet valve . If the ice maker holds the ice , and does not dump , replace the ice maker . When you open the freezer door , the laser light , should blink twice , then pause ,repeatedly . If you close the flap on the left side , the laser should go off . These are indication that the optics are good . If you open the door , and no laser light , then that means that the ice maker is in the harvest (dump) mode . If it stays this way , ice maker is bad .
Sep 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Mod: 10651262103, icemaker leaking, not making ice
We need to know if the ice maker overflowed or if there is a crack. Sometimes the water gets frozen in the fill tube and diverts the water everywhere other that ice maker. Rare but sometimes something causes the water control valve to stick open on rear of refrigerator. Your ice maker has a thermostat inside it and starts a cycle when the thermostat says the water has frozen. That starts a cycle of about six thing to happen.The defrost element below ice maker warms the bottom just enough to loosen the ice. Micro switches feel and sense the position and as it nears ending the final step the ice maker tells the water control valve to open for a few seconds. An adjustment in that control may stop over flow. But if cracked in a major section it will need to be replaced. Let me know if this helps you. Sea Breeze
Jun 20, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Maker Stopped working
Hello, I don't know if this will help because the model I have is a 106.565(32)400. I have had my ice maker stop working many times because the fill tube was iced up. After about the 8th or 9th time that it did this I decided that I had to find a solution. What I came up with was that the door in front of the ice maker was keeping the tube too cold and making it freeze up. I removed the door to see if was correct. It never froze up again but the ice would fall out sometimes if you had the door open and it was in the dumping cycle. Then I drilled several 1/2" holes in the ice maker door and reinstalled it. I have had no more problems for over a year.
CYA, Gator241
Jan 05, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore mod. 59672822200 ice
you should at least have power to ice maker. be sure to check while depressing the light switch assy. some ice amkers are wired through door light switch.after that there should be awire guid. tech sheet under the kickplate to guide you along if needed
Mar 13, 2008 | Refrigerators
GE 15.7 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White Logo
41 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
