Question about Porter Cable C2002 150 Psi 6 Gal Compressor
My compressor hose is running extremely hot...any reason why and do i have anything to worry about
  • 160 Answers
Assuming that it's used in an open-air spot so that the intake air is cool, hot compressed air means the head is running hot.
Most small-to-mid sized compressors run warm after a few minutes, and some run fairly hot after 10 minutes.
If the hose is too hot to hold after 20 minutes, the first suspect is friction within the compressor's head.
This could be caused by poor circulation due to a low-quality oil.
It could also mean a blockage in the air-delivery system (ie: oil-dust gunk at a fitting causing restriction, making the motor work harder than normal.
Flush the oil reservoir, pull the feed lines one-at-a-time and flush out. Pull the intake filter and blow out the head & valves.
Refill the reservoir with Craftsman compressor oil.
Posted on Sep 08, 2010
I have an Emerson Refrigerator Model No: CR286BSE and it out of nowhere it stopped working and know it is making a clicking noise and will not cool anything at all but the compressor gets hot.
Your compressor is shot, I would recommend not letting it run, it could over heat and develop a leak, the refrigerant is extremely toxic, and if it ignites creates Phosgene gas which is incredibly dangerous. IF, you can find a compressor for the model it may be worth it to replace it, or buy a new one. Good Luck!
Dec 04, 2016 | Emerson Refrigerators
D55570 compressor troubleshoot
I had a similar problem and it was the valves one had lost a small piece.
Dec 24, 2017 | Dewalt Air Tools & Compressors
What would cause hose from pump to tank on a porter cable pancake comressor get extremely hot when running
It is normal for the line going from the compressor to the tank to get very hot in all air compressors. Compressing air creates allot of heat. It will get hot enough to cause burns if touched.
Nov 18, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I have a brand new mini fridge, the type with a freezer as well. Its compressor has been getting extremely hot lately (too hot to touch), but it's still keeping everything cold and the freezer is still...
It is possible that the setting of the thermostat is too high and that the compressor is finding it hard to reach the set temperature thereby making it work so hard so as to heat up. Now as per design this must not happen but if the thermostat or the auto defrost does not work then the compressor might be working too much and so will BURN OUT in the long run. The compressor might warm up but not HEAT.
So if the fault stays with a lower settting please contact dealer for warranty. If not this seems to be a fault with the compressor and you must stake claim for warranty.
Sep 27, 2011 | GE Refrigerators
I noticed the steel braided hose which is the intake for the air supply is very hot to the touch. Like extremely hot and was just wondering if this was normal? I removed the air filter and tried running...
I believe the hose you are referring to is the "Aftercooler" that connects from the head (outlet) of the compressor head to the air tank. Under normal use, the aftercooler will get very hot. Air is heated when compressed and will heat up this hose and the inlet area of the tank.
Oct 15, 2017 | Dewalt D55270 gas powered air compressors
Doesn't dehumidify
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 01, 2010 | Fedders A7DH45B2A Dehumidifier
My 98 jeep grand cherokee seems to be leaking coolant out of the top of the motor close to the airconditioning compressor.. it makes a slight hissing btiu i cannot find the source of the leak i checked...
if there is a bypass or heater hose in that area check that out by wiggling the hose when its prtessurized. be careful not to move the hose to much, it may break, may be extremly hot (Gloves help) if you move the hose back and forth sometimes you will hear a change in the hissing sound. i hope this helps you
I’m happy to help further over the phone at https://www.6ya.com/expert/gregory_8e6ba270263743ac
Sep 16, 2009 | 1996 Jeep Grand Cherokee
Pressure will not build up in the tank and the silver tubing gets extremely hot.
There is a moisture release valve under the tank that may have been left open. If so, close it and the pressure will build. The reason the tubing heats up is because it is running so long.
Sirwriter
May 17, 2009 | Stanley Factory Reconditioned Bostitch...
2004 FORENZA
OF COURSE GOOD IDEA IF POSSIBLE REMOVE BELT OFF COMPRESSOR IF THE UNIT SEIZES THE THE CAR MOTOR WILL STILL TURN THE BELT WHICH COULD GET EXTREMELY HOT APART FROM THAT NO WORRIES HOPE THIS HELPS GLENN....
Nov 14, 2008 | 2004 Suzuki Forenza
Compressor is extremely hot
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
Jun 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Porter Cable C2002 150 Psi 6 Gal Compressor Logo
475 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
