Question about Cub Cadet Garden
My cub cadet GT 2554 is leaking oil. what are the likely causes, and how expensive are the repairs?
  • sueb1309 Sep 08, 2010
    thank you for your help.
  • 11,800 Answers
The most obvious cause would be the transmission - one of the ring seals on the shafts is worn out. To replace the seal and a thorough inspection (if one seal has failed the others can't be far behind) - around $400. If all the seals on the transmission must be replaced - around $450.
Posted on Sep 08, 2010
Cub cadet 2554 low power and using oil and sputtering
Probably blown head gasket, fairly simple to replace go to youtube.com and watch video.
Jul 30, 2017 | Cub Cadet Garden
Engine is smoking on Cub Cadet LE-100 edger. Is it because of old oil, and if so, howdy I empty the old oil?
Sounds like the rings are leaking. Changing oil will help. look on engine crankcase and see if there a screw type plug the bottom of plug should be facing down. Look in yellow pages and find a repair shop and ask them how much to repair. Sometimes it may cheaper to buy new unit
Jul 02, 2017 | Cub Cadet Garden
Why is my cub cadet push mower leaking oil from the filter, filled it used 3 times and it's empty
Either the filter has a hole in it or when you installed it, you cross threaded it and it leaks.
Sep 07, 2015 | Cub Cadet Garden
How do i get a siphon hose out of the oil tank on my cub cadet gt 2000?
unless you can get it with a clothes hanger or tear it apart,does it hurt to leave it?
Jul 11, 2015 | Cub Cadet Garden
Kokler courage 20 on cub cadet was running locked up had plenty of oil but oil ran out bottom of engine
Check the motor mount bolts they are probably loose and vibration and torque cracked the crank case and the oil leaked out of engine while it was running locking engine.
Feb 05, 2015 | Cub Cadet Garden
Cub cadet 1050 hydro trans after about an hour of cutting the mower does not want to pull up hill. could this be a belt issue?
the belt tension could cause the mower to not pull on a hill you can pull on the belt and if it's flopping around also look at the belt for signs of oil oil leaking on the belt will also cause the belt to slip
Jul 07, 2012 | Cub Cadet Garden
Cub cadet 2554 GT just stalled and won't turn over?
check the fuses and cables safety switches
May 25, 2012 | Cub Cadet Garden
What type of oil and how much do you use in the Cub Cadet 1440?
It would take 3 and 1/2 pints of Cub Cadet Engine oil (Recommended):
SAE 30 for temps > 40 degrees Fahrenheit
10W30 for temps 0 - 40 degrees Fahrenheit
5W30 for temps
Sep 27, 2010 | Garden
Garden Logo
246 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
