Question about GE 15.7 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White
Ice maker stalled - GE 15.7 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 11, 2010
The ice cream mixture froze to the cylindar walls.
is that not what is supposed to happen . ice cream is a frozen dessert .
Dec 06, 2015 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Er IF on the display and the ice in the ice maker is melted
check the fan on the ice maker, chances are its stalled with Ice ,
Jul 19, 2011 | Kenmore Refrigerators
I have a Kitchen Aid KSRG25FKSS17 side by side refrigerator and ther ice maker stopped working. I got the ice out of the tray and it filled up with water and the fingers cycled around but will not push the...
Good day,
When ice cubes are formed, a thermostat embedded in the ice maker closes, and then starts a motor that cycles the rakes, ejecting the cubes.
When the fingers of the rake hit the frozen cubes, the motor stalls.
However, there is an electric heater embedded in the bottom of the ice maker that at the same time is heating the well of the ice maker, freeing them up and allowing them to be discharged.
You should remove the ice maker, to see if there is a foreign object that fell into the well, preventing the cycle from continuing. If so, remove the item and reinstall the ice maker.
More commonly, the motor has weakened or the heater has failed. In either case, replacing the ice maker is your only option. There are in some cases a repair possible, but it is not cost effective.
Sep 21, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Whirlpool refriigerator ice maker not working
With ice makers it is almost always one of two things. The ice maker itself, or the water valve. Figuring out which one is easy, and I will help explain.
First thing is the frig has to be cold enough for the ice maker to even start working. I'm assuming we have the cold part taken care of. Next, the machine will start a cycle and ask for water. Here is where the valve comes in. The ice maker energizes the valve and it opens allowing water to rush up the back of the frig and into the ice maker. After the ice freezes the ice maker goes into harvest and dumps the ice.
In conclusion, you either have an ice maker that stalled at some point during that cycle (in which case you need a new ice maker). Or the water valve is not opening, thus no water enters the ice maker and you get zero ice.
If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
At this point you will hear the water valve energize or not. If it never energizes, the ice maker is not working right, if it energizes and you get squat, the valve needs to be replaced.
If you have experience with a multimeter you could detach the harness going to the ice maker and simply hook up your leads. When the ice maker asks for water, you should get 110v reading on the meter. If you do, the valve is bad and needs to be replaced.
If I can be of any further assistance please let me know. good luck!
Oh, and the valve probably sells for between $50 and $100 depending on where you buy it. The ice maker should run between $100 and $180.
May 29, 2010 | Whirlpool GS5SHAXN Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker stopped making ice
With ice makers it is almost always one of two things. The ice maker itself, or the water valve (valve is located on the backside of the frig, bottom right hand side almost 100% of the time). Figuring out which one is easy, and I will help explain.
P.S. There is a remote chance the filter needs to be replaced. An old filter can cause water pressure issues and you may not get enough water into the ice maker.
May 29, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker stopped making ice...no water coming into maker nor does the unit appear to be rotating...water dispenser works fine.
Quick facts: If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
May 28, 2010 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
The ice stripper on my icemaker has warped. Its
when ice maker goes into harvest the unit stall on the ice /the heater comes on and when tray is warm the ice moves out on the stripper . . i would think the tray is loosing its coating and the ice does't release and the heater stayes on too long . may have to replace the mold or ice maker .. ****
Jan 18, 2010 | Refrigerators
Ice maker makes ice but will not rotate and dump the ice.
You have a thermostatically controlled heat release ice maker. Any number of issues can cause a failure to "dump" the ice. The harvest is started when the thermostat closes. A motor rotates the ejector fingers which are at rest in the 2 o'clock position. The ice maker operation will stall until the heater releases the ice from the mold. After the cubes are ejected into the ice bucket, the water valve will refill the mold with water to begin the next cycle. Lack of ice dispensing could be a failed thermostat, heater, motor or switch contact withing the ice maker module. You could simply replace the ice maker and save the expense of the service call.
Dec 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker does not extract ice cube's to the pan
Take a short piece of #14 insulated wire and strip both ends about 1 inch. Bend the wire into a "U" shape. Insert the stripped ends into terminals "T" and "H" inside the ice maker cover. The gear should start to move. After the gear has moved 1/4 turn,remove the jumper wire.If the heater and thermostat are good it will drop ice and refill. If not it will stall.
If the motor does not move at all or the motor stalls, replace the ice maker.
May 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE 15.7 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White Logo
51 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
