Question about Philips Audio Players & Recorders
My old Philips AH848 amplifiers won't give sound anymore, i've removed the left channel power transistor and one of it is blown, what else should i check now?
  • 5 more comments
  • jetbot007 Sep 08, 2010
    Btw they are power transistors (darlington) with a big heat sink. 2 for left channel and 2 for right channel.
    I haven't checked it by re-joining the fuse again, should i start the amplifier and check if right channel gives any output?
    Got it, i'll go keep one pair which isn't blown, and reconnect the fuse.
    Okay, i'll check those transistors later, i have to go and i have a serious headache now.
    I'll reply, when i'll get back later.
  • jetbot007 Sep 09, 2010
    Okay, so I followed those small transistors, there are 4 of them. Each one for each darlington. Collector of two BDV64C and two BDV65C are connected to each other with a small capacitor. So it's yet not sure which pair is of left and which is of right. And the transistors are not insulated to heat sink. And yea those big resistors were connected to emitter.
    And all the four transistors Collector and Emmiter are short.
  • jetbot007 Sep 10, 2010
    Okay, rechecked the diode and transistor.
    Right heatsink's collecter are short to chasis.
    Left's collecter shows current around 70
    The emitter and base for all darlington transistors show approximately same current output.
    Okay, rechecked the diode and transistor. Right heatsink's collecter are short to chasis. Left's collecter shows current around 70 The emitter and base for all darlington transistors show approximately same current output.
SOURCE: Output volume has dropped in right channel
dear sir,pls check the HT voltage fuse, LTsupplay also and out put stage,and volume controle,
Posted on Feb 01, 2007
  • 21 Answers
SOURCE: Amplifier problem
You may have a blown channel. Check for fuses inside but I don't think that it will help. Repair if the channel is dead is not worth doing as the amps value is probably lower than repair cost.
Posted on Sep 03, 2007
  • 54 Answers
SOURCE: hafler dh220 power amplifier left channel distorsion
Sounds like your Power FET's are gone. Take it to a shop that specializes in high end or vintage gear. ....good luck...Rob
Posted on Mar 03, 2008
  • 4234 Answers
SOURCE: Blown Channel on an amplifier
Look for low valued resistors that may look ok, but be open. Check the emitter resistors (.22 or .47 ohms). Check the transistors in the driver circuit as well.
Dan
Posted on Jun 06, 2008
petraman7
  • 1175 Answers
SOURCE: Proton 520 Integrated Amplifier with quiet left channel
Hi...
Flush all the switches and controls with De-Oxit D5 or better.
Then get back to me.
Thanks
Posted on Mar 01, 2009
Yamaha ax440 left channel down
Check both your input(rca) and output connections on the inside of the amp for any looseness or damage, solder connections and so forth.. However I think your power/output transistor(s) are burnt in the left channel
Apr 08, 2013 | Audio Players & Recorders
We have an old amplifier from back in the 80's and 90's. Its 500watts, the right channels (both main and sides) work fine and loud, but the left channels produce very low sound. I checked the fuse and its...
Have you checked the final transistors on that weak channel? They may look fine but may be weak. You can pull them and check them on your multimeter with the diode check and cross it with the data sheet for that transistor.
Mar 07, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
No power after i unhooked the wire from amp, left wire uncovered at ends for couple days tried hooking them back up and no power now. is amp blown
if you unhooked the wire from the amp while the amp was on, you may have possibly blown a fuse, or mayb a transistor or compacitor inside the amp! easy fix, just find new transistors and compacitors and soilder them on after removing old ones!
May 03, 2010 | Rockford Fosgate Punch P8002 Car Audio...
Power transistor number
Hi again! Been thinking about this and you might not need to wait for someone to answer. I assume the transistor in question has blown apart or burnt up so you can't read the number?
However does it come off the heatsink as part of the main amp? If it does then it might have a brother around it. For if it is say the left or right channel transistor, then the other channel will have the same type transistor. Remember the left and right channels are copies of one another. If you see 4 transistors on the heat sink then it's a push-pull amp. They work in pairs, one pair for each channel. By the way it's best to replace the pair, even if only one is blown.
If on the other hand the blown transistor is from the power supply section, then you will have to wait for someone to help, or get the service manual.
Jan 24, 2010 | Audio Players & Recorders
Only get sound out of right side both a and b
Good day sir, Hi, your Philips receiver trouble can be any of the ff:
  1. your receiver left fuse is blown, check if it has a user fuse at the back. or
  2. your main IC amplifier for the left channel is bad. you need to replace that IC, but check first the wiring of the speakers.
  3. Check your receiver left speakers if it is producing a soft hum, to do this turn down the right channel, or adjusting the balance knob to the left, or simply remove the speaker connection of the right channel. place your ears on the left speaker as you adjust the volume up and down, do you hear a soft hum that goes up and down also? If yes the problem is on the source section before main amplification, usually the pre-amplifier stage, If you hear no hum at all. problem with the main left amplifier. The main amplifier is usually a single IC for both left and right channel, OR one IC amplifier for the left and one for the right, in both cases, replace the bad IC.
Jan 21, 2010 | Philips Audio Players & Recorders
Amp won't power up,anymore! Even with new parts installed,removed
Hiya, dont have a diag either what you will have to try and is compare the left channel with the right. There will be 2 driver transistors (also likely on heatsink) close to the outputs. Check which driver drives which output on the left, then match it on the right. Those same drivers could very well also be a problem on the right as they often go with the outputs. There is a possibilty they have smoked again. See here to test FETS
http://www.4qdtec.com/mostest.html
Basically the left will match the right but not similar locations but definitely by track joins.
Also check the power resistors at the output. Often also go.
Hope that helps
Jul 15, 2009 | Car Audio & Video
Audio distorsionado en canal izqierdo
the input selector switches if they are dirty can make the amplifier sound like it has a blown channel.
compare voltages from the left and right channel and make sure they are identical as well as the power supply,typically + and - 65vdc .check the regulators for the pream,they run panel lights off the same circuit + - 14vdc
May 26, 2009 | Marantz Audio Players & Recorders
ADCOM GFA 5802 POWER AMP NO SOUND, BUT POWERS UP.
Remove the output transistors and measure each of the sets of 3 pads and report the voltage readings here. I suspect that you have either a blown driver circuit or output transistors. The voltage readings will give me an idea on where to start looking for specifics.
Thanks,
Dan
Nov 11, 2008 | Adcom GFA-5802 2-Channel Amplifier
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
NAD C350
Take a ohm meter and measure resistance from emiter to collector should have a few kilo ohm on output transistor.
If no ohm meter available , remove output transistors from circuit.
note position of transistor . you have a NPN and a PNP for each channel.
Replace fuse and power up. If fuse blows check bridge in the power supply.
80% of the time output transistor burn and blow the fuse.
before replacing output transistors check driver transistors they probably burnt also
Apr 29, 2008 | NAD C350 2-Channel Amplifier
649 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
