Question about Dell Optiplex GX270
Want to add another 512 stick memory to dell optiplex 270, it has one already. Will it speed up my computer
  • 320 Answers
Hi yes it can speed up, first you need check in your manual what type of memory your pc is use, then buy stick with same specification witch is in otherwise it can slow your pc. Sometime it better replace it for one stick 1Gb if it help please rate it regards
Posted on Sep 08, 2010
How does this computer compare to a Dimension 5000 with same RAM amount and clock speed?
Paulji786,
Below are the specs you requested on these 2 systems.
Optiplex GX280
Memory
Type
400 & 533 MHz DDR2 SDRAM
400 & 533 MHzMemory connectors
small form-factor computer: 2small desktop computer: 4desktop computer: 4small mini-tower computer: 4mini-tower computer: 4
Memory capacities
128 MB, 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory
dual-channel: 256 MBsingle-channel: 128 MB
Maximum memory
small form-factor computer: 2 GBsmall desktop computer: 4 GBdesktop computer: 4 GBsmall mini-tower computer: 4 GBmini-tower computer: 4 GB
BIOS address
F0000h
Dimension 5000
Type 400- and 533-MHz DDR2 unbuffered SDRAM
Memory connectors four
Memory capacities 256 MB, 512 MB, or 1 GB non-ECC
Minimum memory 256 MB
Maximum memory 4 GB
System clock 800-MHz data rate
Memory speed
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 15, 2015 | Dell OptiPlex GX280 PC Desktop
I have a Dell GX620 that I rescycled.It wouldn't power up so I put in a different power source and put in 1 - 512 stick of memory. It then started up and I reformatted the hard drive and re-installed...
just leave in one of the new 1gb stick of memory
if stable memory was the issue so add the back one at a time each time shut down install turn on test
if still unstable coould be the hard drive
May 29, 2011 | Dell OptiPlex GX620 PC Desktop
What is the most memory l can put in my dell optiplex gx 280 desktop ,l have 512 in it now
For mini-tower and Desktop
You should have 4 slots.
4GB is the max if you replace all the sticks.
For gx280 SFF (Small Form Factor)
You should have 2 slots.
2GB is the max if you replace all the sticks.
Nov 17, 2010 | Famous Brand Dell Optiplex GX280 Intel...
Need the drivers for my gx 270 for the ethernet controller
On another computer, access the manufacturer's web-site:
http://support.dell.com
Enter 'GX270' and do a search.
Select the "network" device-driver.
Download it. Copy it to a USB memory-stick.
Take the memory-stick to your Dell computer.
Install the device-driver from the files on the memory-stick.
Oct 14, 2010 | Dell OptiPlex GX270 PC Desktop
Trying to fit new 1gb memory stick in dell optiplex sx 270 but the system will not acccept it and not boot up error codes of ab yellow but cd green all it does is beep when fitted yet i refit the 256mb...
Hello.
Memory is not interchangeable. Depends on your system, as to what memory to use. An error is telling you the memory is not correct for that PC.
Your Dell Optiplex sx 270 uses DDR PC2700 and DDR PC3200 memory.
Hope this helps.
Dec 20, 2009 | Dell OptiPlex SX270 PC Desktop
Will not load programs
Hi, First make sure your new stick of RAM is being recognized. If you dont get it seated well, it could not really be recognized. Also important is how full your Hard Drive is. This can effect you system speed. Get rid of uneccessary programs and junk files. Also check for background processes and programs that may be using up available memory.
Char S.
May 20, 2009 | Dell Optiplex 755 Desktop Desktop Computer...
Dell optiplex 280 ddr2 memory information
You cannot use drr667 on this computer since it only supportr ddr533, and it will be better if you use one stick of 1GIG RAM since your motherboard supports up to 2 GIG of RAM...
Dec 02, 2008 | Dell OptiPlex GX280 PC Desktop
I have two dell computers, dell dimension 4600, and dell optiplex gx270 smf. I've checked into upgrading the memory on the gx270. It says that it uses the same memory configuration as the dimension 4600....
even though the memory stick sizes are the same, and the speed, there are other differences between memory types, such as parity/non parity, 2x32, 16x4 etc. more than likely, the speed of the memory sticks are different. the easiest fix for this is put the slower memory sticks in bank0 and bank1 (logical numbering used) and then the faster memory sticks in bank3 and bank4. this will cause the faster memory sticks to run at the speed of the slower memory sticks. If your sticks are parity and non-parity mix, then you will probably not be able to combine them.
Sep 26, 2008 | Computers & Internet
Dell Optiplex GX270  Logo
mukhtar21 shaikh
mukhtar21 shaikh
