Frigidaire front load washer has a safety door lock mounted on back of door which has broken. Model 417.3901289
  • Washing Mach... Master
  • 19,396 Answers
Hi.
You can purchase the part online clicking here. Please use the diagram in the distributor website to locate the defective part and to purchase the replacement part.
Posted on Sep 08, 2010
Frigidaire washer door catch is stuck, washer won't run
After looking at the schematic of this machine it seems that the door AND the control board have to work perfectly together in order for the safety mechanisms to operate correctly. You may have a bad control board or a loose wire. The best thing to do is look closely at a schematic and make sure that everything looks right. here is a blueprint: http://www.pcappliancerepair.com/model/index.php?id=FWT449GFS1
Jan 03, 2014 | Frigidaire Affinity ATF7000E Front Load...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washer model ATF6000ES1 door not locking, the door closes, but it's not recognized by control panel.
You are having a problem with the door latch sensor indicating everything is connected correctly. Check to make sure your door is not sagging and then make sure the door latch is not broken or cracked.
Jul 22, 2012 | GE Energy Star WCVH6260F Front Load Washer
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
I am trying to find a part number for my Frigidaire Front Load Washer - Part No. FTF2140FS0. Can you help? the plastic door latch (I think it's called the Safety Door Lock) has broken off. We can't find...
Alisa hi hun this is shonna neeley out of ohio i just recently had same problem u did and had heck of time trying find parts for my washer is the same as your i will give you the link where to go to order your parts for that washer it help me out greatly when i went there been buying there every since anywhooooo help is on it way doll.
Replacement parts in Cabinet/top section of FRIGIDAIRE FTF2140FS0 Frigidaire/washer
copy and paste this let me no if it helps i,m on facebook as shonna neeley if you need my help cause i strugled getting help from anyone / on my washer and dryer..
Dec 13, 2010 | Frigidaire Affinity ATF7000ES Front Load...
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Motor wont run
Your door lock is bad. Don't trust the door lock light because this will fool you. Even tho door locks 1 of the circuits is not continuing. Replace the door lock. Very easy to do. Do this by peeling back the door boot at the lock side. Reach hands inside for access to wiring and remove door lock switch.
Jan 31, 2010 | Frigidaire GLTR1670A Front Load Washer
I have a frigidaire front load washer model fwt449gf. What is the best way to get the door safety switch out? The front seal appears to be glued on so that route is not available.
You can carefully pry off the seal with a knife or similar tool, focusing on the glue points which on mine were at the 2, 4, 8 and 10 o'clock positions. I then installed a door lock switch kit which came with glue/cement to glue it back on once you are done, but you could probably use any good general purpose contact cement because the seal wants to stay put on its own.
Nov 17, 2009 | Frigidaire FWT449
Broken electronic connector on washing machine
seawolrf your going to have to do a little work...open the door now looking at the washer i want you to take a knife or screw driver and take that gasket off right next to the door switch,,the black gasket is glued ,,yes glued pull it up..only by door switch..now remove door switch screws (2) now replace that connection...onthejob
Jan 27, 2009 | Frigidaire FTF530FS Front Load Washer
Frigidaire Front Load Door Lock Broken and Noisy FWT449GF
Its looks like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Good luck!
Sep 08, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
