Question about Canon Cameras
When I turn the camera on, the screen displays the last picture taken. I can take a picture but there is nothing shown in the viewing screen before I take the picture, so I don't really know what it is I am taking a picture of. The menu screens come up when pressed but nothing else appears to help. I have a PowerShot A720 IS.Thanks for your help. Sincerely, Barton G. Stone bart.stone@pincock.com
  • 10,515 Answers
This is a common problem on this set. This is either due to faulty CCD sensor or faulty LCD screen. Look at the previous recorded images or videos. If you see the same white lines in previous saved images or video's , it would be suggestive of LCD screen unless it is a faulty CCD sensor.
If that is LCD panel, it is not worth repair.If that is CCD sensor, then you could call up Panasonic to check whether CCD sensor of your model is under recall or not.
Read an old article :-
http://www.imaging-resource.com/badccds.html
If it is not under recall, try to get some good replacement or repair at low cost unless invest in new camera.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 08, 2010
Can see through the viewfinder but not the lcd screen
On this camera the display will turn off when closed. There is a microswitch that controls this. If this switch is bad, the camera will think the display is closed. Have it checked
Aug 05, 2014 | Canon PowerShot SX20 IS Digital Camera
Intermittent blanking on pictures displayed
There's nothing wrong. The blinking areas are blown-out highlights. These are the portions of your picture that the camera thinks are overexposed.
While viewing the picture, press cursor-up/down to cycle through the different views of your picture.
May 06, 2012 | Nikon D40x Digital Camera
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am...
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 29, 2011 | Canon PowerShot A630 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera: The camera LCD display is extremely dark with shadows/outlines of reddish pink hues and the same image is shown when a picture is taken. I have tried transferring...
Did u check the settings of the camcorder? see the setting there you got contrast settings if its low then you'll get dark images or its exposer meter's problem U check the exposer meter's reading and see aparture also.
Mar 09, 2011 | Cameras
Display screen no longer works while taking pictures
Sounds like they accidentally pressed the DISP or DISPLAY button on the back of the camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time with the camera turned on.
Aug 01, 2009 | Canon PowerShot A630 Digital Camera
Black screen
Try cycling through the Display button until you're able to view photo to be taken.
May 06, 2009 | Sanyo VPC-S500 Digital Camera
CANON POWER SHOT SD750 DOESNT TAKE PICTURES BLACK SCREEN
Mine started working again. The only thing I can attribute to it is that I zoomed the lens in and out several times. The next time I turned it on, it worked. Go figure. I'll update if things change.
Dec 03, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
A95 LCD screen black and unable to take photos
Its common problem in canon cameras and I have solution. please let me know if you didn't find in chat.
Sep 02, 2008 | Canon PowerShot A95 Digital Camera
Cameras Logo
19 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
