Question about Hotpoint RB787 Electric Kitchen Range
I went to use the auto clean on my oven....turned the knob to "auto clean" then turned the oven door latch to the right to lock it. i found out the auto clean took 4 hours (don't have time to do it today) turned the knob to "off" then went to turn the oven door latch back to the left to unlock it and it won't budge...it feels like something stuck or something...?
  • Hotpoint Master
  • 43,501 Answers
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on Sep 08, 2010
SOURCE:
How do I lock door for self cleaning
Some ovens have a latch handle between the top of the door and the actual range top that you have to push sideways to lock. May also be a lock button you have to push in while moving the latch handle.
If you don't see the latch handle, The lock system may be the hidden type that should lock automatically when set to clean. Once the oven is set properly for clean, a motor will latch the door by itself. After the oven gets close to clean temperature, the latch gets locked out and the door will not open until the clean cycle is complete and oven cools down to normal room temperature again. This is a safety feature so you can't open the door while the oven is at clean temp (about 850 degrees). Hope this explains enough. If door never auto latches, could be a problem with the latch/lock system and motor.
Mar 29, 2015 | Ovens
How do you use the self-cleaning ??? i lost my manual within minutes of getting....
we have a sears kenmore model and this is how we do it. remove everything from stove including the racks, close oven door, slide door lock latch to the right till it locks the door. turn knob to clean. when it is done cleaning it will turn off by itself. on some models the door latch will not slide open when done. just wait for it to cool if this is the case. it should tell on the touch pad on stove the hours that it takes to clean it. good-day !
Jan 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
How do i reset the locked oven door to unlock it?
I have had that problem once.I turned off the breaker to that oven over night and then in the morning the door opened as it should.I found a GE page that is below.It may help.
http://www.geappliances.com/search/fast/infobase/10000161.htm
Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
May 16, 2011 | GE JTP15 Electric Single Oven
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
How to self clean a 1989 model self clean GE oven How do I set?
I found that you cannot turn the CLEAN knobs both off before you release the latch on the door. You cannot unlatch the door
if the Oven Set knob is turned from Clean to Off.....it must still be on Clean to unlatch....simple, huh? Well, it was confusing
at the time!
Dec 01, 2009 | GE Ovens
I CAN'T UNLOCK MY OVEN DOOR!
First get rid of the noise by turnining off te breaker.
You will have to pry the lock open.
This is common I use a small screwdriver and coathanger wire,then pull out oven enouhg to replace lock.
Mar 12, 2009 | Ovens
Oven door on lock
is the light oven on??? can you see the switch/button that the door would hit against to turn light off?? if so depress button so the lifht goes off, and start a clean cycle.This should make the lock mechanism engage fully. then cancel cycle and should fully disengage lock/latch (you need to depress light switch to trick unit into thinkin the door is closed)
Mar 08, 2008 | Kenmore 30169 Electric Single Oven
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
I fixed the automatic oven door lock on my oven. While the door was open, I pushed the button on the upper left hand side a couple of times (the one that senses when the door is closed.) Then I was going to call the repairman when the door closed! I had to run the self clean cycle again to get the lock light to go off, but it worked!
Nov 25, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Self clean light blinks when you turn oven on (oven does not work)
I had this same problem with mine (still posted under unsolved) This is the simpler model with the old turn style knob and the lever you slide over to lock the door for cleaning What I think (keep in mind I know little about ovens, more about cars) is that the switch that tells the oven the door is latched is staying engaged, and this is part of the lever mechanism. I cleaned and lubed this mechanism (obviously I would guess you want to use a food safe lubricant) and then moved the lever several times with the oven on so I could see if it turned on. After a few tries the cleaning light went off and the oven light came on. No, its not really a technical answer, all indications to me where that the problem was in the switch which is part of the latch mechanism. Good luck
Nov 26, 2006 | GE JGBP26 Gas Kitchen Range
Hotpoint RB787 Electric Kitchen Range Logo
348 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
