Question about Garmin Nuvi 660 GPS Receiver
My 650 nuvi is not functioning correctly. The screen is frozen and does not respond to touch. It was frozen in the page saying that I needed new maps. Unable to install new mapms through the internet I purchased a dvd because I figured it would be easier, but I still coulnt do it. I finally to it to the geek squad. Five geek worked on my problem, they downloaded the maps to the computer and then to the device but the screen is still frozen.
  • Garmin Master
  • 2,130 Answers
Of course it's still frozen because the touchscreen is defective. If your unit's serial # begins with a 12P, 14V or 143, then you have a style of touchscreen that can fail. Please see this link for more info.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Sep 09, 2010
My Nuvi 650 screen reads "The following map data is more than a year oldand should be updated. When I touch the "OK" on the screen, nothing happens, it seems the screen has become unresponsive.
I would suggest some caution here. I have noticed a trend in anything that can be updated by the consumer---they just blindly do it and I have also seen as the result of this dozens of units crash and burn---if you have not issues and the unit functions why risk losing it?
Turn this unit off and see later if turned on it functions or not, failing that the only way out of the mess would be a call to the maker.
Don't just blindly say ok, kind of like getting a email with a virus and saying OK.
Dec 20, 2012 | Garmin nuvi 650 GPS Receiver
Non-responsive touchscreen, cursor flashes top left will not allow to input pin code, loads maps and all buy no touch screen function, also did reset on back a few times nothing. Ken
I have a non-working Nuvi 650 with same problem. Garmin tech support says they do not support the Nuvi 650 and I will have to buy another one. My Garmin was only 2 years old when it failed.
I doubt I will be buying another Garmin.
Dec 28, 2010 | Garmin Nuvi 660 GPS Receiver
Screen on my Garmin Nuvi 650 is frozen (no reaction to touch). Cna move through screens via the on/off button. Haven't updated maps...ever. Seems like most repairs will cost me $25 just in shipping. ...
The problem with the gps device is a minor one. First you ensure it is properly charged, then you reset it by holding down the power button for about 15 seconds, then it will restart and you will be able to touch the screen once again. If that does not work, then you need to calibrate the screen, take note that calibrating the screen does not just work the moment you try it, you need to try it repeatedly till you get it right. This is how to calibrate your nuvi:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen for about 30 seconds until the calibration screen comes appears (white screen with touch dot),
  4. Follow the on screen instructions.
It is an easy fix. The solution above will help you out on that. Another solution is for you to remove the battery and fix it in back. That should also help.
I have a garmin nuvi 660. the touch screen isn't working
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Touch screen not responding at all. Garmin powers up okay.
This is Garmin's response to me after having the same problem on a 2 year old Nuvi 650: We are no longer replacing or repairing this model unit. However, let me give you some steps to try to calibrate the screen of your unit. The following 'Fix' did not work. I won't be buying another Garmin.
To recalibrate the touchscreen on your nuvi 600 series device please follow the steps below:
  1. Plug the device into the computer via USB data cable
  2. Double click My Computer (Mac Users can skip this step)
  3. Double Click the Garmin or nuvi drive
  4. Double click the Garmin folder
  5. Delete the GUPDATE.GCD file (if this file is not on the device please skip to the next step)
  6. Unplug the GPS device from the computer
  7. Power the device off
  8. Press and hold the Power button
  9. After a short period a screen should appear that says Touch Dot
  10. Release the Power button
  11. Touch the dots as they move around the screen.
Your touchscreen should now be recalibrated.
If the screen is still not responding, then the unit will need to be replaced with a new unit at this time.
With Best Regards,
Benjamin B
Product Support Specialist
Automotive Team
Garmin International
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Benjamin B, Associate #6891
www.garmin.com
Additional solutions may be found at http://www.garmin.com/garmin/cms/site/us/support/searchsupport
Sep 05, 2010 | Garmin nuvi 650 GPS Receiver
Touch screen not functioning
Please see this link. Most likely uou have one of the newer SHARP touchscreens that is known to fail prematurely.
- Jim
Dec 15, 2009 | Garmin nuvi 650 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
970 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
