Question about Jenn-Air JDB4000A Built-in Dishwasher
I have a seven year old Jenn Air JDB 4000 AWB Dishwasher. The door handle is stuck inside the door panel in the depressed position and will not release. The door will not open. How can I get the door open?
SOURCE: Front Glass Door Panel on Jenn-Air JDB1270AWF Dishwasher
Hi again,
You think that liquid nails would be too permanent, so you're wondering if I can suggest an adhesive that would 1) not react adversely with the white paint on the glass panel 2) would not dissolve the black rubber-like adhesive (which has let go) that's between the glass panel and the small brackets, and 3) would be strong enough to hold the glass panel, which is where the DW handle/pull is located, and which is subject to stress caused by constant opening and closing.
Different adhesives are available in diferent parts of the country and they are all subject to proper instalation. So I'm going to sugest some guide lines. 1) You're going to have to do a little leg work. You're going to talk to different people in different hardware stores telling them about your three requirements. You'll be surprised at the varying degrees of knowledge. Don't argue, just take notes. 2) Once you've settled on a product it's time to test it. Find a small piece of glass and aply it to metal useing the adhesive. After drying you can tell if it is satisfactory. If not go back to no.1.
3) Once you're happy with the test find a pair of C-clamps and two blocks of wood. Aply adhesive, then using the wood blocks to protect the glass use the C-clamps on each side. Be carefull not to overtighten. Do this with the door horizontally. Just watch the adhesive, when it starts to squeeze out, stop. Make sure the clamps are aplyed evenly. Be carefull. Good luck.
Harvey
Posted on Oct 01, 2008
vitg55
  • 73 Answers
SOURCE: jenn-air JDB-2100aws dishwasher not drying
1. If you do not use Jet-dry liquid in detergent dispenser left side compartment, the drying result for dishes will be very poor.
2. You should check the heating element for continuity(conections for heating element under bottom panel of d/w).
Posted on Dec 15, 2008
appldoctom
  • 311 Answers
SOURCE: Dishwasher is noisey when the pump is starts to pump water around
yes somthing /pice of somthing has gotten into the works;usually its a chunk of glass or small pice of plastic.no eazy way to fix.youl have to drain and go from the top down.[removing wash impeller pump cover and keep going down each time taking parts off and looking for some small hard somthing.im afraid youl end up going all the way down to the chopper/food grinder.leave the screws in the parts you take off so wont get mixed up.take your time.ive done it hundreds off times i know you can pull it off ,once.you can do it.ps you can let it run like that thru some loads to see if will grind up or clean its self out.knowing what i know i would have no problem trying that on my dish washer.and have done it a few times.hope that helps God bless,tom
Posted on Jan 03, 2009
  • 258 Answers
SOURCE: door spring on dishwasher broke
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
http://www.howtofixanything.co.uk/howto-260.html
Posted on Jan 15, 2009
SOURCE: Jenn Air dishwasher door won't close
i had the exact same issue. it's a broken latch mechanism, and is a fairly common problem.
i bought the part at my local repair shop for $45 (you can find it online for $30). it literally took 10 minutes.
you need to right size bit to remove the 10 bolts on the interior of the door. once you have those out, the latch slides right out of the top. there are 2 electrical connectors (careful - you can get a shock. disconnect the 2 connectors, reconnect to the new one, and zip your 10 bolts back in. super easy
Posted on Oct 17, 2009
Where can I get a parts manual for a Jenn air JDB-5
Try aplianceprosparts.com , they have all the diagrams for upper , lower and middle racks , and doors also , I ordered some rollers for a jenn air dishwasher last week and they delivered the part very fast and that was regular shipping, also the best price around , some other web site had it for 50 bucks + taxes and I paid 38 bucks + taxes and s&h! good luck.
Jul 08, 2014 | Jenn-Air Dishwashers
I took the inside of the door off my Jenn Air dishwasher and now it won't start
You broke it!!!!!!! Check out the wiring associated with on/off cycle. There might also be a switch by the door designed to not allow unit to turn on when door is open - check it out. It might not be engaged if the inner panel of door is not properly hitting the switch.
Aug 22, 2017 | Jenn-Air 24 in. JDB1100AWS Built-in...
How do I unlock my dishwasher door?
To avoid damaging the mechanism, you must remove the cover of the dishwasher and with a screwdriver blade can unlock the door from inside.
Jul 04, 2013 | Cars & Trucks
Adjust door tension on jdb-5 jenn air dishwasher, door too heavy
There are springs on both sides of the door, likely one has snapped. You can get at the spring without removing the machine, sometimes, by pulling the bottom panels...
Jul 02, 2011 | Dishwashers
Dishwasher displaying L# what do I do??
press start and light will not come on and start
jenn-air dishwasher jdb-5
Nov 14, 2010 | Jenn-Air JDB1095AW Built-in Dishwasher
Jenn-air JDB-2100aws dishwasher not drying properly
Dec 15, 2008 | Jenn-Air Dishwashers
Door doesn't want to open on my Jennair JDB 1080 dishwasher. Gets stuck, like the latch doesn't spring open. What can I do to it?
The handle is broken. You may have to force the door open so you can work on replacing the handle.
Nov 24, 2008 | Jenn-Air Dishwashers
Jenn-Air JDB4000A Built-in Dishwasher Logo
63 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
