Question about Haier ESA3067 Air Conditioner
I have a Haier ESA3067 air conditioner that has worked fine for a couple years. Then it began to have trouble responding to the pushbuttons to raise and lower temp, etc. Now it has stopped running altogether. When the unit is first plugged in, the display lights up "88" for a few seconds, then goes dark. If the GFI on the cord is tripped and reset, the display stays dark. It will not respond to pressing the on/off button. Can the problem be fixed by replacing the touchpad? Or is there another control unit involved?
  • Haier Master
  • 17,130 Answers
Yes, rightly said that it is the main controller unit that hass failed . It will worth a try to remove the board and reset the touch pads once again after resolderring on the connecctions of the microprocessor and the connectors to the display.
Check the main +5 volt to the micro processor, check the filter and regulator if the voltage is down.
If not a replacement board can be thought of , but a trail spare to confirm ultimately will be worth unless you can confirm if the mP is not oscillating at all.
Posted on Sep 08, 2010
Haier window ac constant red light? No label next to red light. Turns on and off fine. Cleaned filter, no change. couple years old. Still cools down the room but not as cold as it used to. Help?
Sounds like the unit is just dirty. The AC pulls air through coils and contains dirt, pollen, grease and all type of pollutants. These contaminants will cling to the coils, reducing the AC ability to transfer heat.
Here's a great YouTube video explaining how to properly clean a window AC. How to Clean Window Air Conditioner
AC units should be cleaned every year (including the whole house units), to maintain their ability to cool efficiently.
Aug 13, 2016 | Haier Heating & Cooling
Won't change from fan mode
you more than likely need a new control board or front display control board
Aug 09, 2013 | Haier Heating & Cooling
I am using a Haier HWR05XCJ, and the unit will do nothing but display "E0" when plugged in. Not even the power button responds outside a couple of beeps. Filter's clean, so I'm unsure...
As you have probably discovered, Haier for whatever reason, doesn't list any of the Error Codes in your Owner's Manual. To find out what "EO" means and the solution for it, you must contact Haier Customer Support 1-877-337-3639.
Hope this helped you and thanks for choosing FixYa.
Aug 24, 2011 | Heating & Cooling
My haier a/c model esa3067 wont turn whit out the remote but i have lost the remote how can iturn i tryed pressing the power botten on the ac but didnt work
It have the same one, but pushing thr power button does work. Are you sure there isn't a blown circuit? Double check your outlet with another device...like a lamp. Sorry I can't help more.
May 26, 2011 | Haier ESA3067 Air Conditioner
First day using the esa3067 and when the a/c is on the unit shuts off after about 5 minutes. It keeps doing this, it wont run the a/c for longer than 5 min...
Is the temperrature setting set to a level that is lower than the room temperature. If not set the thermostat to a still lower level and check. If the fault is still persisting then the thermostat can be faulty. If your AC is a new one it will be better to get the warranty on the machine than to do any work on it.
The controller unit can also be an area of suspect.
Sep 01, 2010 | Haier ESA3067 Air Conditioner
E1 code airconditioner not working
Hi Baygirl, you didn't say what model you have, but you can normally find the codes explained on the manufacturers web site. UYou shoulda bought 1 with a remote though - I hate getting off the sofa
Jul 10, 2008 | Haier hwr10xc6 Air Conditioner
Haier wall-unit AC wont work
Try unplugging the machine, waiting a couple minutes, then holding down the power button as you plug it back in. Hopefully you will hear a "beep". Then unplug it again, wait a couple minutes, and plug it back in. This procedure works for clearing the "E1" code from some of the Sharp models, so maybe you will get lucky and the same manufacturer made the control board in your machine! Couldn't hurt to try it out. ;)
Jul 31, 2007 | Haier HWC08XC1 Wall/Window Air Conditioner
Haier ESA3067 Air Conditioner Logo
101 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
