Question about Kenmore Elite HE3 Steam 8674 Dryer
My kenmore he3 dryer door keeps opening when operating. Thus stopping the drying process. What should I check and replace?
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The door latch is broken...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
www.shopyourway.com > Manage My Life > Questions
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
Why won't the buzzer shut off on my Kenmore 80 Series ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Kenmore elite he3
most front load washers and dryers have locks on the doors some have a bottom panel that u can remove to manually unlock door using the release before opening any machine please unplug machine from wall sometimes even unplugging it and waiting a few seconds will release door lock from itself
Feb 09, 2014 | Dryers
The dryer door always pops open stopping the dryer... how do I make it stay shut so the clothes will get dry without having to close the door every other minute?
Try putting less of a load in dryer. The weight of the clothes riding against the door, may be the reason why it pops open.
Apr 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
F20 Error for Kenmore HE3 Gas Dryer
make sure your vent for the dryer isn't starting to get clogged or it may have a hole in it therefore hot moist air is getting in the closet instead of outdise
Sep 07, 2009 | Dryers
HE3 dryer stops drying with code E1
Hi, how are ya?
The E1 is a thermistor problem. It's a little black fuse that's next to the thermal fuse on the duct housing.
It's pretty easy to fix. You need to take the bottom pannel off and then the black blower housing.
Good luck :)
Aug 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Felt 'washer' coming out of front of kenmore he3 dryer. dryer is not drying clothes. 2-4 cycles for a small load
Typically the problem you are having is caused by lint in the vent pipe or a partial blockage where the dryer vent ends out doors. pull out the dryer, remove the vent pipe and check it all out. then go out doors and check from that end
Jun 08, 2009 | Kenmore 82822 Electric Dryer
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore dryer wont stop buzzing
The ECU is faulty - or the timer.
Check/replace as needed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Kenmore 98702 Stacked Washer/Dryer
Not Drying
Had the same issue with my Whirpool. If the clothes are getting hot but not drying then there might be a build up of lint in the exhaust duct and/or passage. Once I replaced the the duct and ran a snake with a brush through the passage (my dryer was on 1st floor, vent ran up to 2nd) and cleaned out the lint build up in filter area it worked like new. Also keep in mind if you use dryer sheets they will leave an invisible residue on your lint filter thus restricting airflow. This can lead to the heating element burning out. The lint filter should periodically be scrubbed with a soft brush (an old toothbrush will do) under warm water with detergent (I use Dawn). This should keep the airflow moving through the dryer instead of keeping it in the drum. Hope this helps.
Oct 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 Steam 8674 Dryer Logo
299 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
