Question about Smeg FME24X Microwave Oven
I have a Smeg FME24X 900 Watts Microwave Oven, and has stopped working, no power but occasionaly the display lights for a fraction of a second, any ideas? Have tried replacing fuse in plug but still only get an occasional flicker of power on the display? please help. Yours hungrily,
  • Smeg Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 10, 2010
My smeg microwave will not heat the food ...... possible causes
If everything else is working but it won't heat the food, the causes are the magnetron "common failure" or the high voltage capacitor and diode can be a factor, the three work together to heat the food. Depending on the nature of repair it can be close to the cost of a new microwave oven.
Feb 27, 2011 | Smeg FME24X Microwave Oven
Need intruction to operate microwave
I am writing to ask how to set the clock on the FME24X 900 Microwave Oven
Just need to know how to set it and where can I get an operating manual from
Area we live in is Windsor
Nov 14, 2010 | Smeg FME24X Microwave Oven
Fme24x not heating and burning smell with loud noise
Those are classic symptoms of a bad magnetron tube, the microwave source. It is possible to replace the part, but usually not worth it. The magnetron is expensive and you should let a professional do the repair. There are lethal voltages under the cover and the chance of microwave leakage if the repairs aren't done correctly. Between the part cost and labor charge, it's usually not much more expensive (sometimes even less!) to buy a new oven.
Oct 31, 2010 | Smeg FME24X Microwave Oven
Smeg SA987CX error message E plus a high pitched continuous sound. Need to disconnect power to stop. This only seems to happen when I microwave. Does anyone know what is wrong and how to fix.
Sounds like the Magnetron in your Microwave has shorted out causing it to scream .. lol own purely none technical term .
Its actually a harmonic caused by the magnetron's anode resonating , usual fault caused by breakdown of the filaments , it is pretty much had it a new magnetron would cost almost as much as a new microwave . it may just possibly be the power supply with an oscillator fault but again that is a symptom of a serious power drain problem that also points to the mag ... sorry Regards Vortash
May 13, 2009 | Smeg FME24X Microwave Oven
I have recently been given a Smeg microwave, product No, SA987CX, but I have no instruction manual and would like to know where I can find one.
I have looked and I can't find one either. You can mail Smeg in the UK at support@smeg-service.co.uk They may be able to point you in the right direction.
Mar 01, 2009 | Smeg FME24X Microwave Oven
Need to remove this fitted SMEG FME24X Microwave
Thanks for the quick reply. As you said this has been mounted into a recess and surrounded like a picture frame.
I found some screws are very deep inside the recess and it has been obstructed by the grille/frame.
If you have any pics or any illustration, can you please forward it to me.
Thanks
Oct 24, 2008 | Smeg FME24X Microwave Oven
Oven not coming on but timer and lights working
The door switches are almost certainly the culprit - probably the upper one. It may also be a loose mount, or even a loose spring in the hook-like devices on the door which activate the switches. There is a center monitor switch whose purpose is to blow open the fuse if the door is open and the upper or lower switch gets activated. That's why the fuse blew when the screwdriver was introduced - you activated the door switch while the monitor switch was on. I've attached a generic picture which gives you the idea. More importantly, at my Web site, I have critical safety information, disassembly tips, and infomration on checking and replacing door switches. You can find these via my link at FixYa here: http://tinyurl.com/yzjozk
Feb 03, 2007 | Smeg FME24X Microwave Oven
Smeg FME24X Microwave Oven Logo
299 people viewed this question
Top Smeg Microwave Ovens Experts
William Miller
William Miller
jason
Are you a Smeg Microwave Oven Expert? Answer questions, earn points and help others
