Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Brother MFC 845cw..."unable to change 51" error... when you power on the printer, it initializes as it should then says "printing", you hear movemnet in the printer, but then the change 51 error comes on....there is no paper jam.
pineworks
  • 4041 Answers
SOURCE: brother mfc-845cw error unable to print 4f
Hi there
Ok try see if this work.
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Posted on Feb 27, 2010
pineworks
  • 4041 Answers
SOURCE: my brother printer mfc-845cw is giving me an error
Hi Ok try this it may work.
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
  • 51 Answers
SOURCE: paper jams??
click here to download yor required drivers
Posted on May 12, 2010
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
Printer screen reads unable to print 50on my MFC-845CW
I would reinstall the driver and see if that first fixes the problem. be sure to restart the printer and the computer after installing the driver.
You can find the driver from here:
http://www.brother-usa.com/downloads/default.aspx?PGID=5&R3ModelID=MFC845CW
Jul 15, 2011 | Brother MFC-845CW multi-function...
Unable to clean 50 (brother MFC-845CW
Hi, to clean up brother MFC-845CW
Open the printer
Remove the ink cartridges from the print head.
Use cotton swabs dipped in hot water to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab.
Once finished, allow to dry and replace the cartridges
Try to print something now
You can also use the manual for help.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Jun 14, 2011 | Brother MFC-845CW InkJet Printer
Unable to print 51, Brother MFC-845CW
Error code #51 - encoder strip may be stained with ink, purge cam shaft broken.
Note: error codes for inkjet printers are different than lasers.
Aug 21, 2010 | Brother MFC-5840CN All-In-One InkJet...
My brother printer mfc-845cw is giving me an error unable to print 51 can you help me with it
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
To exit type 99
Also can try.
Solution:
· Machine off
· Press 80
Nov 09, 2009 | Brother MFC-845CW multi-function...
Unable to print copies
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Brother MFC-845CW InkJet Printer
Error messages
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
Dec 29, 2007 | Brother MFC-845CW multi-function...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
365 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
