Question about Kohler Memoirs Centerset Lavatory Faucet with Classic Design in Vibrant Bru
One of the handles on my Kohler faucet does not turn (at all). The model is very similar to the Kohler Memoirs centerset faucet I've noticed that the other bathroom faucet (dual sinks) is beginning to be a bit stiff in turning as well.
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Removing the faucet stems and coating them( inside and out) with plumber's silicone lubricant should solve the problem. If the stem is too corroded, you may need to replace the stem.
Posted on Sep 08, 2010
How to fix a locked-up hot water handle?
Hello friend,
ALL of these taps (im english !!!) faucets ? have a LIFETIME guarantee. see http://www.faucet.com/kohler-k-8201-4-polished-chrome-taboret-centerset-bathroom-faucet-includes-metal-pop-up-drain-assembly/f230779#warranty-info
'To obtain warranty service, contact Kohler Co. either through your Dealer or Plumbing Contractor or calling 1-800-4-KOHLER or by writing: Kohler Co., Attn: Customer Service Department Kohler, Wisconsin 53044 U.S.A'
Worth a try !!! even if only to find out how to get them apart !!!!
Sep 14, 2014 | Kohler K-8211-4-CB Taboret Widespread...
How do you repair a leaky centerset Kohler forte fauset
That faucet has a lifetime warranty. Call Kohler (1-800-4-Kohler) and tell them you need a new cartridge for a K-10270 faucet.
May 01, 2014 | Kohler Forte Two Handle Centerset Lavatory...
Nut hot faucet
Hi Lee, CCW Lefty loosey, Righty tighty, LOL Have fun at it.
Sep 20, 2013 | Kohler K-10270-4-BV Forte Two Handle...
The cold-water handle on my Kohnler K-454-4S Memoirs Widespread Lavatory Faucet is dripping. Kohler sent me replacement cylinder GP77006-RP, but my handyman can't remove the handle without fear of...
He needs a handle puller. Once the screw is removed the handle puller has a long point on it that goes into where the screw was and then the outside of the handel puller clamps around the handle. You then turn the T part of the puller and up come the handle with no damage
Best of luck Rich
Sep 03, 2011 | Kohler K-454-4S Memoirs Widespread...
I have a 2 handle bath faucet and am trying to remove valve. Can't turn nut either way. Any recomendations to help loosen nut? Which way does the nut turn? The brass nut and stem are pretty green. Been...
righty tighty, lefty loosey. if its too tight for wrench youll need a deep socket wrench that will fit it.my hats off to you. kohler makes a good faucet,if stem is shot you can find new ones at lowes.seat is also replaceble
Jan 26, 2011 | Kohler Forte Two Handle Centerset Lavatory...
Water leaks around the hot water handle when I turn on the water.
what valve do you have. most likely you will need to replace the cartridges
Jul 28, 2010 | Kohler Forte Two Handle Centerset Lavatory...
Hot water faucet has seized up.
the cartridge is either broken or seized up due to rust in the line. make sure you turn the water off to the faucet and disconnect the supply tube from the stop (valve). be carefull with the supply tube , you might have to replace it so have one handy. try to clear the tube. then run a little water out of the stop to see if you have water running to the faucet or if it is plugged with rust. then go to the top of the faucet and remove the handle so you can get to the cartridge. use soft jaw pliers to gently pull cartridge out. look at cartridge and see if the are any defects. if so you will have to replace it , take the cartridge to your nearest Ace Hardware, Home Depot, Lowes , or Menards and show them your cartridge and they will get you a new one. if it is a special order faucet call the manufacturer with model number and they will help you. when you reinstall new cartridge make sure you clear out any debris and use valve grease to lube up your new piece. reassemble and turn water back on.
hope this helps
Jul 06, 2009 | Kohler Memoirs Stately K-452-3S-CP Two...
Dripping faucet
Take a cloth and lay over the top of the stem so as not to damage it. With pliers, grasp the top of the stem and turn it a quarter turn counter clockwise. The stem should lift right out.
Mar 14, 2009 | Kohler Model 102704A: Fort® Centerset...
Kohler Memoirs Centerset Lavatory Faucet with Classic Design in Vibrant Bru Logo
1,232 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
