Question about Minn Kota Maxxum Pro 80 Freshwater Transom Mount Trolling Motor With 42" Shaft
I have an e45 Minn Kota........the electronic control shows that the control needs to be put in neutral.....however it is in neutral.....because of this none of the other features on the led appear and the motor won't spin......
  • tfmarcotte Sep 09, 2010
    I suspect there may be a wiring problem between the throttle control and the board and\or the board and the motor...........I have checked the wires and splice around the connector which seemed to help however but still have incomplete data on LED.............do you have access to a wiring diagram......I'd like to trace the wiring.........thanks
  • 3,083 Answers
This sounds like a control board problem, and you will most likely have to have it replaced. Here is a link to the control board:
http://www.northlandmarine.com/MinnKotaMaxxCntrlBrdKit.htm
Couldn't find anyone else who had this problem, so it's not a common one.
You might check with customer support first, to see if they agree, and here's their site:
http://www.minnkotamotors.com/products/trolling_motors.aspx
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 08, 2010
  • Tom Carson
    Tom Carson Sep 09, 2010
    I couldn't find a wiring diagram, unfortunately- that would sure make things easier. The only people that have wiring diagrams are the manufacturer and service departments, and so if Minn Kota won't supply one, we're out of luck. Contact their support people and see if they can get you one is my only suggestion. Otherwise, find a wise old mechanic/fisherman that might know about these things. Again, good luck to you.
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
    Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
    Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
    http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
    Can get replacement parts for my Minn Kota trolling motor FAQs
    Apr 13, 2016 | Minn Kota Boating
    What is amp. draw of minn kota 40pd? thanks
    Digital Maximizer™
    Digital Maximizer™. Up to five times longer run time on a single charge.
    Conventional speed coil technology wastes energy by delivering a constant, steady flow of power to the motor regardless of the speed setting resulting in wasted energy.
    Pioneered in 1985, Minn Kotas innovative Maximizer™ technology delivers the precise amount of power needed at any setting, along with variable speed control. Now, our advanced, digital microprocessing optimizes draw to extend battery life and reduce damaging heat. Get up to five times longer run time on a single charge.
    Would think you would have to ask direct, but standard practice is to run your Minn Kota from a separate battery anyway, so the draw is pretty irrelevant to main engine starting.
    your manual is here and states it has a battery level meter.
    http://www.minnkotamotors.com/Support/Owner-Manuals/PowerDrive-V2/
    Minn Kota Motors
    Jan 06, 2016 | Minn Kota Boating
    I have a 5 speed forward minn kota only 3 speeds work ,I replaced the speed control box but have the same problem
    Check the Relay's these will be found in the control module, Most likely totaly sealed, test or replacement may be required
    Aug 26, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn Kota Endura 30 Trolling Motor specs
    call 800 number on head minn kota they are very helpful and will fax, email or mail you anything you need.
    Jun 02, 2010 | Minn Kota Endura 30 Freshwater Transom...
    TOOK THE BOLTS OUT OF MINN KOTA AND CANT GET THEM IN. 2 SHORT.
    Hi!
    Here's a schematic:
    Max 74 Bowmount
    Make sure the end housing #7has a small mark in it pointed to the bottom (towards the skeg). The bolts can be a pain to line up!
    Also make sure the armature is all the way forward it can go....past the brushes is the toughest part to get through and lined up. Keep it up, you'll get it!
    Best of luck
    Mike
    Jul 05, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    I need Minn Kota Power Drive operators Manual
    I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
    Jun 09, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn Kota electric motor MKJI1033962
    Best to call Minn Kota direct for the manual Youll need your serial number thrust of motor and shaft length..
    800-227-6433 they will help you with any technical questions.
    Parts can be purchased from this dealer...There are schematics on the site for review....
    http://www.northlandmarine.com/MinnKotaQuickRef.htm
    =100){IAjax.Pop('/WorkArea/showcontent.aspx?id='+id);}else{__LoadTaxonomy(IAjax.getArguements(),'pagerequest=showcontent&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__ecmdiv='+tag);}}function OnDirectoryItemBubble(id,width,event){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=bubble&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&bubblewidth='+width+'&X='+EBubble.EventX(event)+'&Y='+EBubble.EventY(event));} function DmsMenuInit(){ dmsDynamicContentBox = false; dmsCommunityDocuments = false; }function OnAddCategory(name, selectedTreeId, parentId, action, id, type, share){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=addworkspacecategory&__categoryname='+name+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__selectedTreeId='+selectedTreeId+'&__folderId='+parentId+'&__action='+action+'&__taxonomyId='+id+'&type='+type+'&share='+share);}ektj$(document).ready(function(){DmsMenuInit();}); // --> .EkTB_overlayMacFFBGHack {background: url(/WorkArea/images/application/macFFBgHack.png) repeat;}
    Aug 10, 2008 | Minn Kota 40 Edge Bow Mount With Hand...
    Minn Kota Maxxum Pro 80 Freshwater Transom Mount Trolling Motor With 42" Shaft Logo
    27 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
