Question about GE Dishwashers
I have a GE Dishwasher, Model GHD6310L15BB, and when the drain cylce comes on, the dishwasher makes a loud vibrating sound. Can you help me
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 10, 2010
FDB1050remo Making a squeaking sound almost as if a belt slipping. Not overloaded and nothing rubbing on washer blades. My only guess is that it may be related to low water pressure. Is that possible?
please make this test and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 18, 2013 | Dishwashers
Hobart LXiH error E4 AND part makes noise when OFF
test this steps and fix it. GOd bless you
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
Jul 22, 2013 | Hobart Dishwashers
Hobart LXiH error E4 AND a part makes noise when off
test this steps and fix it. God bless you
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
Jul 22, 2013 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 | Dishwashers
Sudden loud vibration from the door of my Whirlpool dishwasher. Replacing the part didn't help.
see this causes and fix it. God bless you
Drain Pump If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 28, 2012 | Whirlpool Dishwashers
Loud humming just started during wash cycle
Humming can be simply due to a mechanical vibration when the wash pump is running. Alternatively it could be the sound of the detergent door solenoid which might be stuck.
Will need make and model number of dishwasher to give further advise. Does the dishwasher complete the cycle and drain out the water?
Feb 13, 2011 | Dishwashers
Loud Humming noise every time we run the dishwasher
Hi, I had this exact same problem. In my situation it turned out to be the pump that pumps out all of the used water. It was rubbing up against the floor so that every time it turned on it made a loud vibrating sound. I just reached under the washer and put a piece of rubber between it and the floor and it solved the problem.
good luck!
I saw this post because I am considering buying the same model you have. Other than the noise problem you have, what do you think of it?
Mar 29, 2009 | Jenn-Air Dishwashers
GE Quietpower 1 Dishwasher
There was no solution, at least no one posted one, so why in the world would I pay someone for a non-anwer?
Thank you.
Feb 07, 2009 | GE Adora GHDA656LSS Stainless Steel...
1 week after installation- is very loud
dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Loud vibrating/humming noise
Okay...based on the model number, this is a Frigidaire manufactured dishwasher. If you go to searspartsdirect.com and type in the your model number in the Search menu, you will find a useful illustration under the "Motor and Pump" heading. The drain pump is listed as item #60 in the drawing. Before you go through any major dis-assembly, check to make sure the pump is securely in place and not loose. Sometimes the pump comes loose from the mounting bracket and vibrates. Also, sure nothing is laying against it causing vibration noises (I've seen this before). If the solution is not that simple, remove the spray arm assembly inside the dishwasher and inspect all the debris traps under the spray arm assembly. The wash pump and drain pump sumps are located here. Check to make sure there's nothing obstructing the input to the drain pump. Lastly, if all else fails, remove the drain pump and inspect the impeller. If the you've inspected everything and still have the noise problem, replace the drain pump. The motor could possible be failing. The part number on the Sears website is 154580301 and costs about $40. Repairclinic.com has the same part listed as item #1257094 for $37.50 if you wish to do some comparable pricing.
I hope this helps you. If you need further assistance, please post back and let me know.
PS Even the quietest of all dishwashers will make some noise. However, if it has gotten to the point where you can hear it in the next room, you probably need to inspect to find the source of the problem. This is not true with all dishwasher manufacturers, but in many cases, the only difference between your "Quiet-Pack" line and regular low-end models is added insulation behind the door and lower panel to help quieten noise.
Apr 21, 2008 | Dishwashers
Dishwashers Logo
270 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
