Question about Jenn-Air Dishwashers
I have a Jenn Air JDB 4000 AWB that is seven years old. I have had several problems with this unit during that time. Yesterday when I tried to open the door the "push handle" stuck in the depressed position inside the front door panel and will not release. The front door is locked shut. I have not tried to force anything (yet). How can I get the door open?
SOURCE: Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Posted on Jun 09, 2008
sicaudio
  • 96 Answers
SOURCE: Driver's side door power locks are stuck; door stuck shut.
sounds like the rods are disconnected the clips hold the rods in place the latching mechanism holds the handle in place as well did you replace the speakers or did a shop? if a shop did then they caused this if you did then you may have caused this either way untill you reattach the rods none of it will work. you will have to manually open the door at the latch from inside teh door behind the panel.
Posted on Jul 19, 2008
SOURCE: Front Glass Door Panel on Jenn-Air JDB1270AWF Dishwasher
Hi again,
You think that liquid nails would be too permanent, so you're wondering if I can suggest an adhesive that would 1) not react adversely with the white paint on the glass panel 2) would not dissolve the black rubber-like adhesive (which has let go) that's between the glass panel and the small brackets, and 3) would be strong enough to hold the glass panel, which is where the DW handle/pull is located, and which is subject to stress caused by constant opening and closing.
Different adhesives are available in diferent parts of the country and they are all subject to proper instalation. So I'm going to sugest some guide lines. 1) You're going to have to do a little leg work. You're going to talk to different people in different hardware stores telling them about your three requirements. You'll be surprised at the varying degrees of knowledge. Don't argue, just take notes. 2) Once you've settled on a product it's time to test it. Find a small piece of glass and aply it to metal useing the adhesive. After drying you can tell if it is satisfactory. If not go back to no.1.
3) Once you're happy with the test find a pair of C-clamps and two blocks of wood. Aply adhesive, then using the wood blocks to protect the glass use the C-clamps on each side. Be carefull not to overtighten. Do this with the door horizontally. Just watch the adhesive, when it starts to squeeze out, stop. Make sure the clamps are aplyed evenly. Be carefull. Good luck.
Harvey
Posted on Oct 01, 2008
vitg55
  • 70 Answers
SOURCE: jenn-air JDB-2100aws dishwasher not drying
1. If you do not use Jet-dry liquid in detergent dispenser left side compartment, the drying result for dishes will be very poor.
2. You should check the heating element for continuity(conections for heating element under bottom panel of d/w).
Posted on Dec 15, 2008
appldoctom
  • 311 Answers
SOURCE: Dishwasher is noisey when the pump is starts to pump water around
yes somthing /pice of somthing has gotten into the works;usually its a chunk of glass or small pice of plastic.no eazy way to fix.youl have to drain and go from the top down.[removing wash impeller pump cover and keep going down each time taking parts off and looking for some small hard somthing.im afraid youl end up going all the way down to the chopper/food grinder.leave the screws in the parts you take off so wont get mixed up.take your time.ive done it hundreds off times i know you can pull it off ,once.you can do it.ps you can let it run like that thru some loads to see if will grind up or clean its self out.knowing what i know i would have no problem trying that on my dish washer.and have done it a few times.hope that helps God bless,tom
Posted on Jan 03, 2009
Where can I get a parts manual for a Jenn air JDB-5
Try aplianceprosparts.com , they have all the diagrams for upper , lower and middle racks , and doors also , I ordered some rollers for a jenn air dishwasher last week and they delivered the part very fast and that was regular shipping, also the best price around , some other web site had it for 50 bucks + taxes and I paid 38 bucks + taxes and s&h! good luck.
Jul 08, 2014 | Jenn-Air Dishwashers
About how old is the jenn-air model# jcd2389des?
Hello, Thank You for using FixYa. I will be helping you today.About seven years old.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Jenn-Air JCD2389G Side by Side...
Dishwasher displaying L# what do I do??
press start and light will not come on and start
jenn-air dishwasher jdb-5
Nov 14, 2010 | Jenn-Air JDB1095AW Built-in Dishwasher
MIcrowave quit on February 15, 2008. I can't get parts to repair
seems like you have to replace the control/touch panel module of the oven.
Mar 21, 2009 | Jenn-Air JMC7000 Microwave Oven
Jenn-air JDB-2100aws dishwasher not drying properly
Dec 15, 2008 | Jenn-Air Dishwashers
Door doesn't want to open on my Jennair JDB 1080 dishwasher. Gets stuck, like the latch doesn't spring open. What can I do to it?
The handle is broken. You may have to force the door open so you can work on replacing the handle.
Nov 24, 2008 | Jenn-Air Dishwashers
Jenn-Air Gas Cooktop Model CVGX2423
you will need to contact your certified local service tech.you might have a distributor problem at yor ignitor box.if the problem is not with your ignitors.
Jun 30, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Dishwashers Logo
53 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
