Question about Precor Exercise & Fitness
I get an error message on my Precor EFX5.17 Eliptical that does not go away and is preventing me from useing the machine. Yhe error message reads " ER54" Can you please help me solve this problem
    Genius:
  • 1,040 Answers
Error 54 - Target Pulses Lost During Operation... Description... This error is associated with the 5.17 EFX. This error indicates that at some time after the initial start up sequence was successfully completed, the gear motor was instructed to move and no response was seen from the motors revolution sensor. Possible Causes (1.) The F2 fuse is blown.... (2.) Damaged or Intermittent gear motor wiring.... (3.) Bad gear motor.... (4.) Damaged gear motor target... (5.) Bad lower PCA.... Possible Remedies.... (1.) Remove power from the 5.17. Remove the F2 fuse from the lower PCA. Measure the fuse with an ohmmeter. The fuse should measure 1 ohm or less. If the reading is significantly high, replace the fuse. If the F2 fuse was blown there may have been a reason that will cause the fuse to blow again such as; damaged gear motor wiring or a bad gear motor..... (2.) Carefully inspect the gear motor wiring for intermittent or damaged wiring or connections. Replace or repair the wiring or connections as appropriate..... (3.) With power removed from the 5.17, remove both wires from the gear motor. Measure the gear motor resistance with an ohmmeter, it should read approximately 9 ohms. If the reading is significantly low or significantly high, replace the gear motor..... (4.) Visually inspect the gear motor target, if it is ripped, torn or badly scratched, replace the target..... (5.) Measure the voltage at the gear motor during the start up sequence, it should measure approximately 12 V.D.C. The voltage would only be present between the time the sequence was initiated and an error was displayed.. If the voltage is significantly low or absent and the F2 fuse is good (see step 1), replace the lower PCA......
Hope this has helped you.... Thanks...
Posted on Sep 08, 2010
EFX 546i eliptical battery location
The battery is usually located at the back of the machine towards the top -- there may be a circuit board on top of the battery. And the second link listed below is a technical bulletin for certain models to help prevent damage to the battery during installation.
This link will take you to the 546i models and parts list. You can also find a parts diagram but you will need to match your serial numbers to the ones listed so you can pull up the correct diagram:
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
http://www.sportsmith.net/images/Pick_Docs%5Cp0645969101-BatteryInstallationWarning.pdf
Feb 03, 2014 | Precor EFX 546i Elliptical Version 4
"stuck key" message on efx 546i, will not engage, already replaced batttery
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Feb 17, 2013 | Precor EFX 546i Elliptical Version 4
How do I fix an ERR70 message on the display of my 9.21 treadmill.
Precor Error 70, LPCA Not Read Probable Cause Incorrect or missing software in the LPCA
Corrective Action Test with a known good LPCA Precor Error 70 LPCA Not Read AMT12 Only
Jan 05, 2013 | Precor 9.21 Treadmill
I get the message error 05 stuck key on my precor efx 546
Corrective Action
Dec 09, 2012 | Precor EFX 546i Elliptical Version 4
Error 44 precor eliptical 546
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Nov 22, 2012 | Precor EFX 546i Elliptical Version 4
Display message reads - "key depressed"
Corrective Action
Jan 25, 2011 | Precor EFX 546i Elliptical Version 4
My Precor EFX 546 Elliptical machine has a "key depressed" error message.
Corrective Action
Aug 17, 2010 | Precor EFX 546i Elliptical Version 4
Whenever I use our eliptical precor efx, as soon as the elevation starts it says error 45
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Aug 10, 2010 | Precor EFX 546i Elliptical Version 4
I am looking for a parts and repair manual for a precor efx546 eliptical unit
Go to National Gym Supply @ gymparts.com or call them @ 1-800-496-7278
Jul 27, 2010 | Precor EFX 546i Elliptical Version 4
I have an Error message 50 coming up when iturn on my eliptical
Precor Error 50, Too Much Brake (Magnet) Current Probable Cause 1. Shorted or damaged wiring between the lower PCA and the eddy current magnet is the most common cause for this error.
2. Bad eddy current magnet.
3. Bad lower PCA.
Corrective Action
  1. Thoroughly inspect the eddy current wiring and connections ensuring that the wires are not shorted to the frame or shorted together. Repair or replace damaged wiring as necessary.
  2. Disconnect the wires from the eddy current magnet. Using an ohm meter, check for approximately 100 ohms across the eddy current magnet terminals. If the reading is considerably low, replace the eddy current magnet. Measure ohms between each eddy current magnet terminal and the frame ground. You should have no resistance between the eddy current magnet terminal and the frame ground. If resistance is present this would indicate a partial short, replace the eddy current magnet.
  3. If the eddy current magnet wiring and the eddy current magnet are both good from the above tests, replace the lower PCA.
Error 50 Too Much Brake Current on Precor Cardio Equipment
Jun 27, 2009 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
219 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
