Question about Whirlpool GGQ8831L Gas Dryer
I have a Whirlpool Imperial Gas Dryer (Model:LGN2000.JQ0) where the heat will intermittantly go on or stay off. Can you let me know what would cause that?
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Whirlpool Imperial gas dryer won't heat up.
There are two thermal cutoffs. If you pop open the top of the dryer and find the heating element the bigger one is mounted directly on top of it and the other one is located below it. Those are the thing to check first. You can test with a multimeter set to test continuity. If those are bad that means that the exhaust vent is getting clogged. Those run about 34 bucks for the set. The other piece to check is the element itself. You can test that the same way. Those run between 50 and 70 bucks. Good luck.
Jun 28, 2012 | Whirlpool Dryers
What would cause no hot air when drying on a whirlpool imperial gas dryer ?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 15, 2011 | Whirlpool Dryers
Wirlpool LEN2000 JQ0 - Not Drying - No Heat Both auto mode and timed - Any Manuals to solve problems. I am very Handy and can trouble shoot.
heatman101
Aug 01, 2011 | Dryers
My Whirlpool Imperial electric dryer runs but there is no heat. I changed thermal fuse already.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool imperial series dryer heats not spinning
This problem is almost always a broken belt. Yes you can do it yourself.
Go to repairclinic. com and put in your model number for the exploded view of your dryer. Locate the belt part number and belt orientation.
Jan 03, 2010 | Whirlpool Dryers
Whirlpool Imperial gas dryer won't spin
It's a broken belt. Replace the tensioner assy also
Nov 03, 2009 | Whirlpool Dryers
My dryer will not heat up
First make sure the circuit breaker on the house 9the one for the dryer) is not popped. it takes only one leg of the 220 to turn the dryer, but it takes both to heat it. If the circuit breakers are ok, you need to check the heating element, and the internal fuses in the dryer.
Dec 26, 2008 | Dryers
We have a whirlpool gas dryer that just stopped heating up. I pulled out the little square window on the front bottom and there is no flame. It is a LGN2000
The thermal fuse is white with 2 prongs. Here is a link. It may also have a round plastic base instead of a narrow plastic base.
Whirlpool GGQ8831L Gas Dryer Logo
270 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
